Engine miss (flatline) and diagnostic trouble
nsmit978
I have a miss or also called a flatline when i hit about 2200 rpm. I read that if you turn your key to the on position and press the accelerator five times the car will run a diagnostic check but I can't get that to work and I thought that would help me. I'm assuming the miss is from an old 02 sensor but I need help on both of these problems.
bigun
i have the same problem does it judder like its got kangaroo petrol in it what engine is it a m20 325i have you done any work on it or did it come by itself
nsmit978
I have an eta engine in it. When I hit about 2200 rpm it flatlines for about half a second then continues to accelerate.
georob
injectors dirty, air leak?
i couldnt get my diag to work either
