leccy window wiring
dazleeds
old skool raver
old skool raver
Post Mon Apr 24, 2006 9:23 pm
ok lets assume my car has no leccy window window wiring at all
i have a pair of wires connected to the motors and nothing else
theres nothing under centre console etc
so how do i wire a up a switch for each window??
as at moment i have to touch live/earth to motor wires to open close
please help :roll:
www.oldskoolfantasy.co.uk
gcorky
Boost Junkie
Post Mon Apr 24, 2006 9:29 pm
oh dear m8-aint you got any looms,would be easier.
i presume you mean make your own wiring?
525 sport
dazleeds
old skool raver
old skool raver
Post Mon Apr 24, 2006 9:34 pm
yeah thats exactly what i wanna do :D
although i could get wires out the breaker if thats easier??
but im only driving the car for about 5weeks
so anything that works on a switch will do
there is previous retro fit wiring but its a mess i gave up with it
:roll:
smithy318i
Post Mon Apr 24, 2006 9:50 pm
dazleeds wrote:although i could get wires out the breaker if thats easier??
best plan by far mate.
this diagram should help a lot .
Post Mon Apr 24, 2006 9:56 pm
Wire back a pair of wires from each motor to the centre console. There's a hole through the middle of each door pillar plug and socketfor the purpose.
Take a live wire from position Q (just to the right of the bottom pin of the four pin radio socket) on the accessories socket behind the glovebox, and an earth wire from the stud with the brown wires above the glovebox, and feed these to the console as well.
Raid the scrappy for a couple of window switches, complete with sockets and some wire attached, and get the cutout as well.
Fit the switches to the console (cut the holes with a craft knife), and connect the wire from Q to either terminal on the cutout.
Connect the wires from the motors to 1 and 6 of the appropriate switch. They may need swapping around to make the windows work the correct way.
Connect the other terminal of the cutout to pin 3 of each switch, and pins 4 and 5 of each switch to your earth wire.
