richo
Post
Fri Apr 21, 2006 7:50 am
hi, im new to the e30 sceen and this website
ive just bought a 325 cabby which is really clean but does tap a little from the top end. i was woundering if anyone on here has had this before? Im guessing that it just the tappits? but what i would like to know is what are they like to adjust to solve this?
any help would be great.
richo
wildeian
Post
Fri Apr 21, 2006 10:30 am
Most probably is tappets, most of them do it!
There are a few thread around about adjusting them from the manufactures specs, unless it is excessively noisy its nothing to worry about.
Might be worth checking them anyway.
Globulator
Post
Fri Apr 21, 2006 12:28 pm
If you tighten them too much it wrecks your idle.
Apparantly a lot of tapping you hear in the car comes
at you thru the steering column. You should be able to test
that by putting your hand over the steering wheel centre,
I tried it but I was being deafened by the funk at that time.
I also have a theory that the adjusters get little flats worn on them
which makes them almost impossible to adjust after a while.
Anyone know if dealers just sell the eccentric adjusters?
richo
Post
Tue Apr 25, 2006 3:46 pm
yeah i did find that thanks charle30. im going to be giveing it a go this weekend so wish me luck!!
gcorky
- Boost Junkie
Post
Tue Apr 25, 2006 7:15 pm
yup ,you may still here the injectors which can tick a bit too.
525 sport
charlE30
Post
Tue Apr 25, 2006 9:18 pm
I think I remember someone saying something about the exhaust manifold gasket aswell, if it's a bit knackered it can add to the noise... I could be completley wrong about hearing it, it might just be from one of my strange dreams
BMW E30 344i track car
BMW F31 335d xdrive
320Touring
Post
Thu Apr 27, 2006 10:10 am
charlE30 wrote:I think I remember someone saying something about the exhaust manifold gasket aswell, if it's a bit knackered it can add to the noise... I could be completley wrong about hearing it, it might just be from one of my strange dreams
you're right dude- a broken stud or leak from the manifold can exibit itself as a "ticking" which gets worse as car gets warmer
