Post
Thu Apr 27, 2006 1:40 pm
well just fitted,had looms clipped in as brian said,fit regs,cut console for extra switches along with door cards clip in.done.
one problem i did encounter,was one side would go up not down,(from console and door)swap over-ok inotherside,ok.hhhmmnnn check plugs loom ok.i decided to remove console switch and swap with the one i fitted into door,yahtzee ok....strip the dodgy switch(clean with switch cleaner bit of wd40 for good measure-box up done.
very nice improvement!!!!
big thanks to Nelly for supplying and BrianMoooore for advise .
525 sport
