320 with good spark/fuel pressure won't start
heraldohiggens
Post Mon Apr 17, 2006 7:35 pm
Hi again Guys
this is another 320 that I'm tryin to get going. As above Ive good spark and fuel pressure, car is turning over and just about to start but does'nt, I also swaped around the ecu with another with the correct numbers, no joy.
I know theres a couple of things I should be checking can you giv me a list?
thanks again
ger
Martinaston
Post Mon Apr 17, 2006 7:54 pm
Crank sensor ?
Check the wires not rubbing on the water pump pully.
There is NO nucleus.
Ant
Retired Team Member
Retired Team Member
Post Mon Apr 17, 2006 8:17 pm
DME relay is probably fubar(5 pin, on strut tower n/s/f), change it for a new/known working unit and try again.
kirils
Post Tue Apr 18, 2006 2:19 pm
i had the same problem with the rellay, it try to start but it wont... i changed it and it's perfect.
DelaneyG
Post Thu Apr 20, 2006 1:14 pm
could be flooded try unplugging the injector rail or removing the fuel pump relay turn it over an let the fuel burn then plug it back in and try again?
Globulator
Post Thu Apr 20, 2006 8:12 pm
Try Ezi-start sprayed down it. If it fires then the injectors probably are not.
You should be able to hear the injectors clicking.....
.... could be DME relay 8O
DelaneyG
Post Fri Apr 21, 2006 6:40 pm
id be careful with easy start it can damage the bore,s if its used too much
