When I bought it, he advised me of a problem with the RPM occasionally going up to 2k ish without any throttle input.
Up till now she has behaved herself, but today, it happened to me for the first time & it's a bit odd to say the least.
With the car fully warmed up (after several trips around and about), I parked up and turned the engine off.
Restarted approx 5 minutes later - idle OK.
Pulled away in 1st (OK), changed up to 2nd (OK), changed into 3rd @ 3k RPM and the revs just stayed there for a few seconds then started bouncing around erratically between 2 - 3K.
Dipped the clutch to take the load of the engine & coasted to the side of the road with the RPM still bouncing rapidly in the above rev band.
Turned the engine off.
Tried several attempts at restarting - engine would just crank over with no hint of firing - slight petrol smell.
Eventually started after a wait of about 10 minutes - idle OK, so set off again.
After about 2 - 3 miles, on dual carriageway at about 75 ish, I could feel the car 'surging' under steady state throttle.
Dipped the clutch and the RPM is back to it's erratic bouncing but I noticed that every time the RPM increased, the fuel economy meter would show massively increased consumption (yes, I know it's supposed to do that before the smartasses come out to play, but this time, it was swinging almost as as wildly as the rev counter ).
Carried on and it cleared itself after another couple of miles and it's been OK for the rest of the day.
Could it be, that the ECU is getting a 'spike' signal from somewhere (TPS or MAF possibly?) telling it that the engine needs more fuel?
I'm almost certain I can rule out a mechanical fault because of the rapidity of the RPM swing.
Anyone any ideas?
Iain S
BTW, the MAF meter and the ICV have been swapped but the problem's still there.
