quite tappety
innes
Post Tue Apr 18, 2006 6:34 pm
is it normal for a 325i to sound pretty tapety?
i think this is the correct description gets quicker with acceleration?
what can i do to possibly quieten them down??
wildeian
Post Tue Apr 18, 2006 6:39 pm
Yeah, mine's the same and I've adjusted them many a time.
There's a few threads going about adjusting the tappets from 10 to 12 (or the other way round), but I think it's pretty normal.
e30-320i
Post Tue Apr 18, 2006 6:49 pm
if you can hear it in the car with windows up some of the sound maybe coming up through the steering column i was told by some-one on here to take horn button off and plug the hole with blue tack sounded odd but did the trick
89 325i touring
StuBeeDoo
Post Tue Apr 18, 2006 6:56 pm
Just a thought, but are you mistaking blowing exhaust manifold gasket(s) for tappets? That would also cause a tick-like sound.
The BlueTack in the steering column does work - the shaft's hollow.
HTH
Stuart.
wildeian
Post Tue Apr 18, 2006 7:21 pm
single point injectors also make a clicking sound.
I was going to buy some multi-hole injectors a while back, but I got ripped off by 'ChippedUk' on eBay.
MattyP
Post Tue Apr 18, 2006 8:32 pm
Dead right about the sound transmitting through the column.
Tried taking the horn cover of and then driving, couldn't beleive the difference!!
:mad:
