What's this?
tjd200
Post Mon Apr 17, 2006 6:17 pm
Any Ideas?
Found after some recent work... and I don't remember taking it off :wink:
Image[/img]
e30-320i
Post Mon Apr 17, 2006 6:20 pm
looks like the erm thing that goes on one of the ht leads
89 325i touring
Chris-W
Post Mon Apr 17, 2006 6:24 pm
And you'd be hard pressed to not remember taking it off the lead!
tjd200
did cross my mind but couldn't figure out how you would get it on (or off)
Chris-W
Post Mon Apr 17, 2006 6:29 pm
It's the pulse generator - you can re-fit it fairly easily by removing the rubber spark plug shroud from the end of the lead.
sibzilla
Post Mon Apr 17, 2006 6:30 pm
thats mad! I need one of those but have to buy the HT leads that come with it attached... how did you get that off without cutting a lead? (and remembering!)
EDIT - just seen the asnwer in the post above - doh :)
tjd200
Post Mon Apr 17, 2006 6:35 pm
any particular cylinder?
and considering I didn't take it off (really... i would remember... i can't have been that drunk...)
must have been sitting on the sump tray for some time. Presumably some sort of timing information that my car's been missing.
So how come I haven't noticed it?
Chris-W
Post Mon Apr 17, 2006 6:38 pm
Goes on number 4, if memory serves.
sibzilla
Post Mon Apr 17, 2006 6:44 pm
I'm pretty sure its HT lead #6 actually... will check.
tjd200
cheers all
Chris-W
Post Mon Apr 17, 2006 6:46 pm
sibzilla wrote:I'm pretty sure its HT lead #6 actually... will check.
Assumed it was a four pot for some reason.....
tjd200
Post Mon Apr 17, 2006 6:47 pm
might have helped had I said... so yeah it's got six cylinders (unless I've lost one and not noticed)
tjd200
Post Mon Apr 17, 2006 8:18 pm
anyone who can tell me which ht lead saves me from getting up early.
Martinaston
Post Mon Apr 17, 2006 8:55 pm
It's not used by the ECU, it only runs to the diagnostic socket so you could leave it off.
There is NO nucleus.
Post Mon Apr 17, 2006 11:15 pm
Martinaston wrote:It's not used by the ECU, it only runs to the diagnostic socket so you could leave it off.
I used to think this, but it's used as a cam position sensor by some 325 motronic set ups as well.
sibzilla
Post Tue Apr 18, 2006 11:35 am
its deffo #6 - presumably its the last cylinder, so a four pot will be lead #4.
I'll let you know if adding this sensor to my car makes a difference as my car feels like its running slightly retarded timing without it (jerking a little on constant throttle in higher gears and a small drop in revs if I touch throttle lightly) - My 325 is a '92 so I think it needs it.
sibzilla
Post Tue Apr 18, 2006 12:10 pm
OH MY GOD!
BMW wants £47 for a replacment! Leads it is, at £68 at least they're new and they come with the sensor!
Ziggy
Post Tue Apr 18, 2006 12:18 pm
Owch! Can't you get a second hand one though? Fairly sure someone will have one sitting in their garage (think I probably have actually!), or your local scrappies...
Post Tue Apr 18, 2006 1:51 pm
Ziggy wrote:Owch! Can't you get a second hand one though? Fairly sure someone will have one sitting in their garage (think I probably have actually!), or your local scrappies...
E30 ignition leads last for ever unless phyically damaged. Scrappy ones will be fine.
sibzilla
Post Tue Apr 18, 2006 3:06 pm
cool thanks guys, if anyone has a spare they'd be happy to part with I'd be most grateful? else I'll just go checking scrappies.
cheers all.
