how to remove diff,,,,
dark_sounds
Post Wed Apr 12, 2006 12:31 pm
ok sounds like a tad silly question,,,
but basically which part do i remove...
the arm that joins to the wheel has the large nuts,, or the nuts that require the allenkey head to remove.. which one should i undo??
pics would be fantastic please :)
dazleeds
old skool raver
old skool raver
Post Wed Apr 12, 2006 12:38 pm
unless ur changing driveshafts as well undo the allens at the diff eachside
get plenty oof wd on everything to loosen em up
www.oldskoolfantasy.co.uk
dark_sounds
Post Wed Apr 12, 2006 12:39 pm
cool cheers mate
dazleeds
old skool raver
old skool raver
Post Wed Apr 12, 2006 12:45 pm
ps dnt try using a normal allen key youll be there forever get one that goes on a half inch ratchet
think its 8mm but double check
and make sure you have energy in reserve for the diff mount bolts at the top there bloody tight lol
slacken the prop bolts first as they will be a nightmare later
good luck
Widge
Post Wed Apr 12, 2006 12:52 pm
I did this at the week end with the car on it's side and dropped the subframe off. I have no idea how people get to the diff top mount bolts with it on the car!
Project_E30
Post Wed Apr 12, 2006 3:17 pm
Widge wrote:I did this at the week end with the car on it's side and dropped the subframe off. I have no idea how people get to the diff top mount bolts with it on the car!
With ease, you have to do it by touch though rather than sight.
Widge
Post Wed Apr 12, 2006 3:21 pm
But is there enough room to get a nice big spanner in? Cos you need a decent amount of leverage.
dark_sounds
Post Wed Apr 12, 2006 3:53 pm
widge i managed it fine :)
ok heres the progress....
undone the allen key things,,, loosened the top mounts, not a big deal....
then realised cant loosen the prob without having other tihng attached, so reattched 2 bolts enough to keep it still...
got one nut from the prop off.. though the others are not budging,, really looking my patience....
its from a breaker car... if i angle grind the prob will i be able to get it off later??
this is the my main problem so far,, ,these damn bolts. for the prop.... any advice??
dazleeds
old skool raver
old skool raver
Post Wed Apr 12, 2006 3:58 pm
all i can say is persist they will come
lots of wd
i did say do prop first mate :roll:
Widge
Post Wed Apr 12, 2006 4:06 pm
Angle grind the prop, I did this at the weekend. Well I dropped the whole prop off as the engine end box habeen taken out. I ended up with the diff and prop on the floor of the garage with the rear crossmember threaded on as it wouldn't fit over the prop centre bearing :roll: corse if you grind it do it after the centre bearing :wink:
Get it all off then jam an old screwdriver or steel bar in the universal joint to undo the prop, got to put you foot on it but it can be done.
dark_sounds
lol i was too eager,,,
blah makes no difference now,, i would be struggling then as i am now... gonna give the wd a bit of time to settle in deep and have another crack,,, then i dont know what to do after that lol
dazleeds
old skool raver
old skool raver
Post Wed Apr 12, 2006 4:08 pm
mucho big spanners and a big strong passer by winkeye
Widge
Post Wed Apr 12, 2006 4:13 pm
fter that you angle grind the prop and do it on the garage floor, it's quite easy really. Just make sure you have like a pole on the end of the spanner about a meter long and they'll just pop off.
Nelly
Gumbo
Gumbo
You can always remove the rear springs for easier access to the diff plate nuts :wink: - don't do what i normally do and get confused with what way to turn a nut LOL, spent a good 1/2 hour trying to loosen one of jonbuoys when all i was doing was tightening it up - still managed a good 1/4 turn though LOL.
Neil.
Big up the WD40 - works a treat once settled in.
"I F**KING LOVE YOU GUMBO"
gcorky
Boost Junkie
Post Wed Apr 12, 2006 4:19 pm
yup widge i required a skin graft shortly after my original 17 yr old rusty shite of a diff decided to come out :cry:
525 sport
Widge
Post Wed Apr 12, 2006 5:00 pm
I think if I had to change diff I would take it as an opportunity to change all the rear bushes!! Have the rear subframe off :wink:
I hope the skin graft has settled in ...not too itchy?
Chris-W
Post Wed Apr 12, 2006 5:08 pm
Just hook the ring end of a nice big spanner over the open end of your 17mm to get the prop bolts off. You can't beat a bit of leverage!
Bob_S
Post Wed Apr 12, 2006 7:42 pm
I've been up until silly hours doing this job at night it's gay but worth it lol
Bollocks to this 24v scrap!
Chris-W
Post Wed Apr 12, 2006 7:43 pm
I've done two roday :D
Widge
Post Wed Apr 12, 2006 7:45 pm
Sorry do you mean today.
Chris-W
Post Wed Apr 12, 2006 7:47 pm
Sorry, I sometimes slip into obscure dialects.....
Widge
Post Wed Apr 12, 2006 7:56 pm
....or press thw erong jey???
Chris-W
Post Wed Apr 12, 2006 8:01 pm
At last, somobw I feek I can communicate wiyj!
stevetigger
Post Mon Apr 17, 2006 4:52 pm
What are you two like??#
Im going to be doing this job tomorrow, so Photo's and updates for my thread!
Im just a bit scared of having the car up on axle stands and reading all this pull hard stuff and the car falling on me! :mad:
Widge
Post Mon Apr 17, 2006 5:02 pm
You got a diff for the beast then Steve??
stevetigger
Post Mon Apr 17, 2006 5:12 pm
Widge wrote:You got a diff for the beast then Steve??
Not yet, 3.25 diffs are rare!
Need to remove mine to sell it to Firefly2005
Post Mon Apr 17, 2006 10:43 pm
Give Nigel Mosely a ring Steve, he's got quite a few :lol:
Thats where I got mine winkeye
Widge
Post Mon Apr 17, 2006 11:21 pm
stevetigger wrote:Not yet, 3.25 diffs are rare!
That's going to triple the budget so far!!!!!
stevetigger
Post Tue Apr 18, 2006 11:38 am
DanThe wrote:Give Nigel Mosely a ring Steve, he's got quite a few :lol:
Bloody forgot about him, A friend of mine's Dad is old friends with Nige
but he is very expensive :?
Widge wrote:That's going to triple the budget so far!!!
Yep, up to £200 :mad:
Ziggy
Post Tue Apr 18, 2006 11:46 am
dazleeds wrote:ps dnt try using a normal allen key youll be there forever get one that goes on a half inch ratchet
Anyone confirm that? I can't remember either... Next weekends job's getting the LSD in! Will probably just get a set of allen sockets, but I can't really see me using any of the others so if they happen to come individually... :cool:
Chris-W
Post Tue Apr 18, 2006 12:24 pm
Yep - 8mm. I manage with a 3/8" ratchet or worst case a 3/8" breaker bar.
Ziggy
Post Tue Apr 18, 2006 12:37 pm
Chris-W wrote:Yep - 8mm. I manage with a 3/8" ratchet or worst case a 3/8" breaker bar.
Ta :thumb:
It'll be 1/2" for me though - I don't actually own any 3/8" stuff!
Widge
Post Tue Apr 18, 2006 12:40 pm
They do come individually, Hafrauds do them. I'll go and check what size you need mate. I've got a Draper set that I think was £25 which isn't too bad as it does the Torx ones for the bumpers too.
EDIT too late!!!!
Ziggy
Post Tue Apr 18, 2006 1:35 pm
Thanks anyway mate - good to know they do em individually too :thumb: I've already got a torx set & with my trade discount ( :D ) a single 8mm shouldn't be too much! I'd be happy to buy a set (more tools is always good), I just can't see where I'd use em...
Widge
Post Tue Apr 18, 2006 2:23 pm
I use them much more than I thought, they're much better than allan keys. I've got a set of those E sockets too, use them more than I thought.
