fast e30
jamesroools
Post Fri Mar 04, 2005 8:20 pm
i got bored the other day and worked out (mathematically.. yes im sad :weirdo: ) that a 327i with approx 200bhp and 200lb/ft, and had the kerb weight of the car reduced to about 900kgs, then it would do 0-60 in sub 6 seconds, like arround 5.5 seconds, this seems rather fast for very little effort, just wonderd if anyone thinks this would actually be possible
Image Image
Adammcf
Post Fri Mar 04, 2005 8:32 pm
To get it to 900kg's you'd have to strip a hell of alot off the car.
jamesroools
Post Fri Mar 04, 2005 8:37 pm
i know, but if it went that quick, it would certainly worth it
Image Image
BIGMRLEE
Post Fri Mar 04, 2005 8:38 pm
not that av nowt beta to do but, i`ve had same sort of thoughts nd it is possible but you`d be driving a shell with not many panels so you get more wind resistance.
Custom and Classics
.Design .Restoration
.Repair .Modification
& Custom Builds
07901602663
LeeHatfield25@btinternet.com
CAR`S, VAN`S, BIKE`S & 4X4`S
Body repairs, bodykits, painting, welding,
exhaust systems. M.O.T repairs
Servicing,
jamesroools
Post Fri Mar 04, 2005 8:41 pm
what about a carbon fibre body? bit pricey though 8O
Image Image
BIGMRLEE
Post Fri Mar 04, 2005 8:59 pm
have to be custom built carbon fibre cos no companies want to know
Custom and Classics
& Custom Builds
07901602663
Servicing,
jamesroools
Post Fri Mar 04, 2005 9:03 pm
yeah prob wouldnt be worth the work, but theres still alot that could be done to reduce weight, especially if you went to extremes
Image Image
Sjoerd320i
Post Fri Mar 04, 2005 9:08 pm
ive seen a site that sels carbon body panels like , dash, doors, boot, m3 front bumper, front wings also m3, hood.
edit: doors are door cards
2nd edit: i found the site :D http://www.e30shop.de
can't think of the site anymore :cry:
6potWil6pot
Post Fri Mar 04, 2005 9:12 pm
Youd probably save a fair bit of weight with Perspex plastic windows instead of glass! :o
jamesroools
Post Fri Mar 04, 2005 9:15 pm
wouldnt that be impossible to clean, and if it got scratched it would need replacing, but if it was gonna go that extreme it wont be that bad
Image Image
redz
Post Fri Mar 04, 2005 9:28 pm
Just stick the lump on a scotter, and watch it fly.
:wink: :wink: :wink:
jonb
Post Fri Mar 04, 2005 10:12 pm
i think you will have your work cut out trying to cut an e30 down to 900kg"s.
ok for a track day special, but useless as a road car. better off buying an e34 m5.
E30Adam
Post Fri Mar 04, 2005 10:16 pm
I seem to remember that Duncan stripped his E30 out and still couldn't get it under 1,000kg's and he was pretty much driving a shell with running gear.
He also had problems with finding springs that allowed it to be low enough. Because it was so light, it sat quite high even on very low springs so there are lots of other things to think about if you're going ot the extremes.
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
