stiff gear change
e30-320i
as above my gearbox is feeling really stiff recently and 1st thing in the morning its really reluctant to to from 1st to 2nd but it loosens up abit after a couple of minutes is there anything i can do to get it back to normal
89 325i touring
Change the oil to ATF.
e30-320i
how do i change gb oil
89 325i touring
wildeian
Drain plug is on the bottom, filler/level plug on the side (r/h side i think)
17 mm allen key required I believe, and some way of delivering the oil 'uphill', as it's quite tight in there!
While you're under there you could check the two linkages on the rear and rear top of the g'box.
e30-320i
cheers guys will put it on the evergrowing to do list
89 325i touring
Oil comes in 1litre squeezy bottles that makes it easy. Just fill untill oil starts coming out the filling hole. Car has to be level of course.wildeian wrote: and some way of delivering the oil 'uphill', as it's quite tight in there!
e30-320i
i have a mate with a pit in his workshop so it should be fairly simple then is it pretty much the same with the diff oil tooBrianmoooore wrote:Oil comes in 1litre squeezy bottles that makes it easy. Just fill untill oil starts coming out the filling hole. Car has to be level of course.wildeian wrote: and some way of delivering the oil 'uphill', as it's quite tight in there!
89 325i touring
Access to the filler is a bit more restricted, but apart from that, the same as the diff.
e30-320i
thanks again
89 325i touring
wildeian
I've always found it a bit of a bugger getting the oil out 'squeezy' style, but give it a go!
Difficult to get the last third out, so just put in part of a bottle, then refill it with another part used bottle, and so on.wildeian wrote:I've always found it a bit of a bugger getting the oil out 'squeezy' style, but give it a go!
