318 to 2.5 conversion
nav786
Post Fri Mar 04, 2005 7:10 pm
Hi, need as much info as possible on the above conversion. ive got a 318 convertible on j plate. What bits (engine, box, obviously) would i need to do the conversion. Is it a straight swap or do i need new mounts, etc.
Andy325i
Post Fri Mar 04, 2005 7:33 pm
It was a long time since I did my old one, but here goes!
Engine(plus mounts)
6 cyl Engine loom
ECU (173?)
Gearbox(plus g/b cross member)
slave cylinder? (may be the same as 318i)
Propshaft
Exhaust system
Radiator
Expansion bottle
cooling Hoses Top/bottom
Other stuff:
Diff (can do later)
Suspension
Brakes
nav786
Post Fri Mar 04, 2005 7:38 pm
how much roughly would i be looking at.
E30Adam
Post Fri Mar 04, 2005 7:39 pm
Are you going to do it yourself?
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
nav786
Post Fri Mar 04, 2005 7:42 pm
my mate will be doing most the work. just needed to know roughly how much on parts. what would a good engine and box cost? and the other bits?
bullitt
Post Fri Mar 04, 2005 8:12 pm
You would be better buying a complete damaged or rotten 325i to get all the bits needed!! 8)
Andy325i
Post Sat Mar 05, 2005 9:20 am
I paid Ԛ£500 for all I needed, which included a LSD :D
