Hi i have a 320i with standard wheels on i was thinking of putting some 15's on fron a sport would this give a fauls reading on my speedo because of the larger dia wheels and would this be compatable with a 40mm spring drop, PS the car is totaly standard at the moment
james
320 wheels and lowering
Strawb
BMW 320i SE Coupe
http://www.gorilla-x.com/jpg/at_ch.jpg
m3ben05
johnna
- E30Zone Irregular
Don't get your drop like this!!!
Bugger! I spotted this finishing off after my cambelt swap.
I think I have a 60mm drop and 15's.
johnna
- E30Zone Irregular
Actually, I meant to say, are the front coils hard to swap? I have rebuilt front struts on Capris before. Any particular pitfalls?
Templ8e30
Although the 15" rims are larger in diameter than the 14" standard rims the tyre sidewalls are thinner giving almost identical rolling diameter so it doesn't affect the speedo.
The 15 rims should have 205/55/15 tyres.
I have these wheels with a 35/40mm drop on my 2.7 (was originally a 320i) with no issues.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
