tweeter/crossover help needed
Bally
Post Fri Mar 04, 2005 5:54 pm
need some asist, got tweeters to mount on door mirror covers ,just want to confim I am wiring correctly.
crossover tweeter connections to tweeter, woofer connection to door speaker, amplifier connection to stereo (ie remove connections from door speaker and connect to corossover where it says amplifier)
Also any idea where these cross overs should be mounted, in door (will they rattle) or behind dash. thanks for info
Dom
Post Fri Mar 04, 2005 6:26 pm
Yes, the wiring is correct.
Don't mount the crossovers inside the door unless your speakers are in the door. Basically you just want as few wires as possible going into the door :thumb:
craigieeb
Post Fri Mar 04, 2005 6:38 pm
i actually mounted my tweeters on the pillar where the seatbelt is (should be in my case) and iv got them pointed towards my ear basicly, sounds great :cool:
E30Adam
Post Fri Mar 04, 2005 7:36 pm
There's a section for this type of question, kindly use it.
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
Bally
Post Sat Mar 05, 2005 6:46 pm
Thanks, tweeters now in sound good, fiited crossover in door as speakers are in door took your advise only one set of wires going into door, used duble sided sticky to hols crossover and stop it rattling.
