Took it to my mothers as I can leave it there safely and of course it wouldnt start again and again I'm smelling petrol, wouldn't start thereafter - typical that its the month that I am more skint than I have ever been
Was serviced last May, I'm guessing spark plugs as everything else sounded normal, just that it couldn't fire up for some reason, fuel line could also be a possibility as I can smell petrol when the tank is full.
1989 325i SE, 140k on the clock, zone chip, recently had timing belt & water pump replaced and garage said that it didnt need a service although the inspection lights (green) have just come up. Also had the battery die on me a few months ago if that would make a difference....
Any ideas?, does this sound like a spark plug / fuel line problem or something more sinister, can't get a proper look at it for 2 weeks as I'm away - thoughts appreciated
UPDATE
Trying to diagnose this from 170 miles away isn't the easiest....
My bro thinks it might be the fuel pump or an electrical problem, he got it started yesterday but hasn't had any luck since....
Any thoughts?
