Pulse Generator ?
m-dtech
Unapproved Trader caution
Post Thu Apr 13, 2006 1:49 am
ETK Part No 12141710668 (item no1 in diagram)
is there any way to test this part ??
No spark from the car and everything is new..
mrLEE30
Post Thu Apr 13, 2006 5:39 am
crank sensor knackered will give same symptoms.
not sure about pulse generator. where does it go to or from in the engine?
mrlee
m-dtech
Post Thu Apr 13, 2006 5:59 am
gearbox to ecu, its early motronic system
there are two, speed sensor and crank sensor iirc.
Widge
Post Thu Apr 13, 2006 9:47 am
Don't think theres a way to test it, substitute another and try.....
dazleeds
old skool raver
old skool raver
Post Thu Apr 13, 2006 9:56 am
pulse sensor wont make any diff to the running at all
its only used for the diagnostics
have taken them off totaly before and all runs perfect
Daz
www.oldskoolfantasy.co.uk
Widge
Post Thu Apr 13, 2006 10:01 am
Intresting.
wildeian
Post Thu Apr 13, 2006 10:03 am
Isn't the picture of the crank sensor?
The pulse sensor is attached to one of the HT leads (No.1 I think)
They both connect at the bracket holding the diagnostics plug.
wildeian
Post Thu Apr 13, 2006 10:13 am
m-dtech
Post Thu Apr 13, 2006 10:25 am
the early cars had the two sensors on the gearbox..
the latter cars had on the ht lead and front pully.
regardless...
all i need to know is is there any way to test with a multimeter ?
m-dtech
Post Thu Apr 13, 2006 10:26 am
wildeian wrote:Isn't the picture of the crank sensor?
one sends a pulse to the ecu which in turn pulses the coil to give spark.
(so im told)
wildeian
Post Thu Apr 13, 2006 10:52 am
is yours the earlier or later model?
resistance between terminal 1 (yellow wire) and terminal 2 (black wire) on sensor side should be 860 to 1060 ohms. resistance between terminal 3 and either 1 or 2 should be 100 000 ohms.
on the later models resistance between 1 and 2 should be 500 to 600 ohms
Post Thu Apr 13, 2006 1:59 pm
wildeian wrote:.
Actual measured value I use is 540 ohms between the two pins nearest to the lead.
m-dtech
Post Thu Apr 13, 2006 2:27 pm
wildeian wrote:is yours the earlier or later model?
pmsl, i posted the part i was querying even the ETK part number 8O
m-dtech
Post Thu Apr 13, 2006 2:28 pm
Brianmoooore wrote:
wildeian wrote:.
so basicaly im looking for 500 ish ohms failing that its fecked.
