I have heard a rumor that the cables are already in position for fitting the oe tweeter pods?
Would this be true, or if not what will i need to fit a set?
Thanks Dave
Tweeter pod fitting
d6dph
DaveD
- E30Zone Wiki Specialist
the wires are there in my cab but there is an earlier thread which says (I think) that there is not a crossover fitted which you will need..but have a look
Project_E30
Dave if you find any info I'd be greatful for it!d6dph wrote:I have heard a rumor that the cables are already in position for fitting the oe tweeter pods?
Thanks Dave
SHAZ325iSPORT
yeh that is true,ive had loads of e30s and not all of them had this wiring option,anyway the wires are coloured i think light grey and yellow,and light grey and light green.
but if you havent got a set of wiring already fitted,its gona be a b*stard of a job(thats only if you do it properly as in through the door rubbers.
DaveD
d6dph
Ah bum, lets just hope its all there! ill take the panels off tonight and see what i have.
Cheers DaveD, Great bit of help
DaveD
we try to please
but let me know how easy it is to get a wire through the rubber thingy to the door as i am about to fit some door builds with 6" speakers .....when the weather gets warmer...and it stops raining
eko
- Old timer
I just ignored the OE tweeter wiring in the end and ran all new wires from the head unit to cross over,then from there to speaker and tweeter!
Also since my original post i have replaced the front pods with the genuine factory ones,but dumped the Nokia tweeter inserts and bonded in the infinity ones,looks original and sounds pretty good too!
Plenty of room to run fresh wire through the rubber boot but a bit fiddly,i used a piece of wire coat hanger,with the new wire taped to it,to guide it through,made life easier.
DaveD
That sounds easier than I was expecting...thanks
