Stock E30 brake SUCK - help
alexbaby88
Post Thu Apr 06, 2006 2:59 am
All my brake components are in good working order, so please limit your suggestions to brake upgrade options.
Am trying to avoid going to 5 lug due to the relative complication and cost.
Please help, the lack of stopping power in emergency braking situations is shocking!
Andy325i
Post Thu Apr 06, 2006 3:47 am
What kind of power are you trying to stop alex?
Have a word with Ian332isport, as I know he is running big brakes on a 4 stud set up :)
HTH
Andy
Widge
Post Thu Apr 06, 2006 9:04 am
Standard E30 brakes don't suck that much, unless you've got more power. I'd up grade your tyres first.
alexbaby88
Post Thu Apr 06, 2006 10:58 am
I do have more power and am on good 205/55 tyres, incl goodridge brake hoses.
Any possibility of using the E32 brake servo and master cylinder? I don't track the car but am more interested in getting more BITE when I need to stop in a hurry, for street applications.
Widge
Post Thu Apr 06, 2006 11:02 am
How much power?
You either need to go to a Wilwood style big brake kit if you've got loads of power - or just a bigger servo?? Or smaller diamiter master cylinder and some performance brakes. I have used green stuff but though they were no better than standard brakes.
alexbaby88
Post Thu Apr 06, 2006 11:40 am
Bigger servo from another BMW? Do you know which?
Widge
Post Thu Apr 06, 2006 12:10 pm
5 or 7 series of the same vintage??? I'm afraid I don't know mate.
Turbo-Brown
Boost Junkie
Post Thu Apr 06, 2006 1:35 pm
If you fit a bigger master cyl, you'll end up wiht LESS bite and a pedal that needs pushing even harder to get the car to stop!
I've got the Wilwood kit and once it's all bedded in, it seems to work great without too much of an increase in pedal travel :D
e30_Turbo
Boost Junkie
Post Thu Apr 06, 2006 1:46 pm
I'd like to think I'm now at the top end of power outputs from a e30 ( RR to confirm soon ) and I run zimmerman cross drilled discs and pagid pads all round and it works fine, although I may need a better qauilty brake fluid as I have boiled mine once or twice :D
I've seen some good options on german ebay, 312mm discs and 4 pot calipers for about 500euros, so there are kits about.
Only issue with most of the kits that are about is the minimum wheel size which will no doubt mean no more BBS's :cry: good excuse to get 16 inch BBS RS's tho :D
Jon_Bmw
Dangerous when thinking
Post Thu Apr 06, 2006 2:36 pm
fozzymonster wrote:I'd like to think I'm now at the top end of power outputs from a e30 ( RR to confirm soon ) and I run zimmerman cross drilled discs and pagid pads all round and it works fine, although I may need a better qauilty brake fluid as I have boiled mine once or twice :D
Trust though mark, try putting it on a track and stopping from 120mph abuot 3 times in a row :eek: Then you'll scare yourself. I agree with what you are saying, I think your setup is fine for the road as how often are you going to be going from 120mph to 30 winkeye
Alexbaby are you planning on running this on a track or just road use, because its a well known fact that you really need track brake setups to be up to temperature before they work well, and how often do you get yours up to "temperature" round town? Another problem you might find is squeling pads if you use uprated ones when cold.
HTH
Jon
e30_Turbo
Boost Junkie
Post Thu Apr 06, 2006 7:10 pm
HTH
Jon
To be fair that is what was happening when we were live mapping the first drive on the new turbo, everytime I looked down at the speedo it said 120 and I was giving the brakes some abuse due to the rdbts at each end of the dual carriage way....that's when the pedal started to go soft and you could smell the fluid in the air.....so I agree Jon, fast road they're fine, for track big disk ferrodo pads and braided lines are a must!
m-dtech
Unapproved Trader caution
Post Thu Apr 06, 2006 7:35 pm
have you tried draining the system fresh fluid and bleeding it ?
Post Thu Apr 06, 2006 7:50 pm
does it make a big difference changing the fluid as my brakes feel like they need bleeding but passed the MOT on efficiency no probs,
They still feel like shit but are there if needed, not a patch on my lads 15 year old corolla,
Any ideas peeps?
Mart. :D
Widge
Post Thu Apr 06, 2006 8:54 pm
Weather they pass an MOT or not is irrelevant. They can't fail an Mot for being spongey as long as the brakes still operate ect...
So you could still have air in the system. Are you sure you have bled them properly??
And what sort of power are you talking about, cos if it's just a chip and cammed 325 than I'd say standard brakes will be fine, but if it's a V12 monster then obviously they aren't.
Lordschleife
Post Fri Apr 07, 2006 2:15 am
If you want more bite then run Ferodo ds2500 pads
I'd also recommend braided hoses and Castrol SRF fluid (pricey!)
If then they're still not good enough for you, think about forking out for a big brake upgrade
Bear in mind whatever brakes you have the tyres need to be good enough to transfer the braking force to the ground.
Shit/cheap tyres will lock up/cause the ABS to cut in sooner, stickier tyres will shorten the braking distance.
You'd be amazed at the difference a set of r-tyres can make (though make sure you're running good fluid with them or it'll boil in no time)
Cheers,
Robin
Andy325i
Post Fri Apr 07, 2006 2:19 am
Hi Robin is the Castrol SRF a race fluid or for road use?
Andy
Bob_S
Post Fri Apr 07, 2006 8:05 am
I will confirm tyres make a HUGE difference in brake performance..
on a wet road I missed a junction just after I fitted toyo's on the front I slammed on hard and they did not lock up on standard 1.6 brakes and stopped pretty damn fast too to the point I had to peel myself off the screen.
My suggestion is to find some grooved/drilled vented disks and a set of good road pads. I know this will improove the braking aswell
Bollocks to this 24v scrap!
Lordschleife
Post Fri Apr 07, 2006 2:46 pm
Yes SRF is a race fluid, but it can be used on the road.
The important thing with brake fluid is the wet boiling point, as after a short time in the car it'll have absorbed moisture.
I've found that fluids such as castrol super, and ATE blue etc are fine when new, but a few months down the line quite easy to boil.
So they are an option if you dont mind replacing your fluid fairly often
As for fast road pads, I'm running Pagid fast road at the mo, and they dont really seem to have much more bite or stopping power than std pads, they should be more resistant to pad fade though.
The guy wanted more bite which is why I suggested ds2500, they've got a higher friction co.eff than most road legal pads
Cheers,
Robin
Post Fri Apr 07, 2006 3:38 pm
Hi Widge,
Its only a 316 (carb) auto , and I have not worked on the brakes at all. Sounds to me a change of fluid/bleed will do it the world of good, as I dont know how old the fluid is.
Cheers mate, Mart. :D :D
Post Fri Apr 07, 2006 3:48 pm
think it is also worth checking if there is any slack on the big old bar that runs from the pesal box to the servo end of things, could be some adjustment needed there to tighten things up and remove any slack/ unnecessary travel.
Widge
Post Fri Apr 07, 2006 3:52 pm
martauto wrote:Hi Widge,
Sorry mate, that comment was aimed at alexbaby88 - cos he said he had more power. Just over haul the system mate, maybe do to 2.5 vented front discs and claipers and rear calipers if you can be bothered.
Post Fri Apr 07, 2006 4:35 pm
Not really worth it Widge, but looking at the full system (overhaul) seems to be the way to go, new pads shoes and fluid wont go far wrong.
Also check out that wassin big bar Lee.
Cheers Lads, Mart.
fuzzy
He who sleeps with "Gingers"
Post Fri Apr 07, 2006 7:50 pm
im running relatively high power for an e30 and i dont find a problem with the standard calipers but have uprated the discs with ebc drilled/grooved items with matching ebc redstuff ceramic pads on the front and greenstuff pads on the rear.theyre fine for the road but i havent tested them on the track yet.
Demlotcrew
Post Fri Apr 07, 2006 7:59 pm
How many miles has the car done?
Andrew
alexbaby88
Post Sat Apr 08, 2006 7:37 am
Thanks for ll the suggestions which I will try to take in. I already have some cross dilled discs all round along with braided goodridge brake hoses.
Can some one suggest some online sites to purchase the Ferodo ds2500 pads?
Cheers,
alex
Lordschleife
Post Sat Apr 08, 2006 11:47 am
The zone shop has the front ones, be warned they're not cheap though, and dont always have the initial bite for the 1st second or so from cold, after that they're great though.
They'll also squeak quite a bit, but you have to remember they are a road legal trackday/race pad
When I bought mine I got them (front and rear) from demon tweaks, had to phone them though
Front fittings FCP303H/rear FCP296H
balancemotorsport seem to do em too
http://www.balancemotorsport.co.uk/pp/B ... _cars.html
Use this procedure to bed them in
http://www.zeckhausen.com/bedding_in_brakes.htm
Cheers,
Robin
alexbaby88
Post Tue Apr 11, 2006 4:44 am
Top Man!
Cheers mate.
Lordschleife wrote:The zone shop has the front ones, be warned they're not cheap though, and dont always have the initial bite for the 1st second or so from cold, after that they're great though.
