Is the 325i sport quicker than a normal 325i, or they both the same??
(manual)
For some reason the sport feels quicker
325i and 325i sport wats the difference?
dazleeds
- old skool raver
pretty sure engines are exactly the same
but the gearbox and diff ratios are different
this will be why the sport feels quicker if im right
Daz
Daz
www.oldskoolfantasy.co.uk
Theo
Sports have LSD, close ratio box, black headlining, mtech kit, mtech suspension as standard.
jonb
yes. sport gearbox has different 1st, 2nd and 3rd ratios.
although not much different from the normal ratios. its the lower diff ratio that alters the overall gearing. although, the sport box does actually have a long first gear, which isnt offset by the diff ratio, which means its stays in first longer than a normal box. i find it really nice.
i wouldnt say sports feel quicker. they are just the same. its all down the the engine. i have a scrap f reg 4 door turd that ive had for a while(and keeping as a dayley hack) it has a great engine which has been looked after, and will muller any sport that has been in my possesion.
fatjapp
Does the black head lining make it go faster then ?Theo325 wrote:Sports have LSD, close ratio box, black headlining, mtech kit, mtech suspension as standard.
Only messing - I'm sure the close ratio box will make it pull better, especially in 2nd and 3rd when you will feel it most.
Lordschleife
The main difference is sports are usually rusty
Cheers,
Robin
Robin
