2.7 conversion
those are the basics yes. but best is if you look for a super eta (129hp) and combine it with a 325i cilinderhead, sharper camshaft and 6-branch.
you can use the other parts of your 320i, except for the injectors, ecu and wiring harnass. those have to be 325i.
offcourse, a 320i isn't capable of controling all that power (aprox. 200hp) so you have to switch your diff and brakes (disc instead of drum at the rear. this will also require another handbrake cable)
so that is all the stuff you will need.
if you need to search for all of these parts, count on +- £1600 for the parts only.
so maybe it is cheaper to find yourself a nice 325i and upgrade that one. with a chip, diesel crank, sharper camshaft and 6-branch u can gaine about 20 hp. so it comes to 190hp. which is quite nice.
greetz.
greetz.
jimmybmw wrote:those are the basics yes. but best is if you look for a super eta (129hp) and combine it with a 325i cilinderhead, sharper camshaft and 6-branch.
greetz.
oh yes ,cant just fit the 325 head as a bolt on .do a search for thorough details.
if you know german, you should go to http://www.e30.de.
there you can find al the possibilities for 2.7 conversion.
Project_E30
Jimmy, I would be really grateful if you could contact me as you seem to know a bit about this. I am really interested in doing the conversion and I dont know German!jimmybmw wrote:if you know german, you should go to http://www.e30.de.
PM's are fine
Project_E30
Have you, or someone you know, done this?Simon13 wrote:fit a 325i head to the eta bottom end, people say it doesn't work but it will. And will be alot better than with a 320 head, if your on a budget
Project_E30
Does it matter if its early or late eta?
So what date of engine should I look for?
this is the one u need for the conversion i did.
http://www.e30zone.co.uk/modules.php?na ... ic&t=31979
at the end of the day you find out that is a waste of money and time I did the 2.7 but it is cheeper to find an m50 and put it in. In ebay I see a lot of m50. On the german site you find the conversion and the driving impression go to
http://babelfish.altavista.com/babelfis ... _en&intl=1
last week I drove an e30 with an s50 (321 bhp) You can't believe it the way it pulls The m50 is ages away from the m20
1991 325 cabio t/c 3.2 evo, 6speed, e36m3 rack, adj bilstein,
http://s241.photobucket.com/albums/ff262/granitsas/
M50 better? yes. M50 cheaper/easier? i doubt it. have you actually done an m50 swap?nikos wrote:at the end of the day you find out that is a waste of money and time I did the 2.7 but it is cheeper to find an m50 and put it in. The m50 is ages away from the m20
http://www.e30zone.co.uk/modules.php?na ... highlight=
not yet, but from ebay I see prices around 450 for the the engine, treehouse racing sells the Wiring Harness ADapter for 399 dollars, then you need oil sump. I dont believe that for an m50 you need more than 1500
I talk about uk ebay just search for a week "bmw engine"
as you can see from my photos I have done a lot on my engine and spent a lot as well, following the same argument as the one we do I WAS WRONG
