what bush?
dark_sounds
Post Sun Apr 02, 2006 7:25 pm
powerflex bushes,, i notice theres eccentric and concentric front bush kit?? whats the difference?? whats better etc??
DaveD
E30Zone Wiki Specialist
Post Sun Apr 02, 2006 7:41 pm
Just put my cab on the road with new powerflex eccentric bushes (and new arb link arms)and i cant believe the difference..so much more positive and the steering is much more responsive and has much more feel
got them from the zone shop... thanks sal,,,arb bushes yet?
Jamesb318is
Post Sun Apr 02, 2006 7:45 pm
Eccentric pushes the wheel foward in the arch, giving you more castor (i believe), hence the handling benefits. Concentric give you less, not sure why you'd want these?!
Sooty
Post Sun Apr 02, 2006 7:54 pm
I could be wrong, but I thought concentric meant the hole was in the middle whilst eccentric meant the hole was offset?
So a std bush would be concentric and a camber correction bush would be eccentric.
Someone correct me if I AM wrong...please :?
max_crox
Post Sun Apr 02, 2006 8:04 pm
Yea, I believe eccentric bushes will correct the camber when you have lowered your car.
All E30 has concentric bushes as standard except the M3 which uses eccentric.
I think... :)
DaveD
Post Sun Apr 02, 2006 8:50 pm
there is a lot of burbling on here ...all the forums and the mags seem to have come to the conclusion that putting the m3 bushes on is an excelent mod...the question was original or powerflex?
ItalianM3
Post Sun Apr 02, 2006 10:30 pm
Powerflex are easier and cheaper! that should answer your question
