Can any M40 owner tell me how their car idles at first start.
Mine pulses up and down between stall and 1K,
but with the ICV unpluged it stays at abuut 600 and doesn't surge.
cheers.
M40 idle
smithy318i
Gwynleym10
- Contact:
In my old SA 316i with the ICV that you sent me, when it was freezing it would idle around 1000rpm, then fall to normal after about 30-40 seconds.
My other one does a pretty similar thing, even though it had a head gasket leak....
The M40 engine 316i that I just bought does this - it does exactly the same, goes from 1k to near stall and then back up again.
Took it out for a run and when warm it idles at 750 but when you stop at a junction it nearly stalls before settling at 750.
What will happen if you unplug the ICV - is it okay to run it like that ?
4 seats is 2 too many.
Gwynleym10
- Contact:
this is what my SA 316i did before i got another ICV for it.The M40 engine 316i that I just bought does this - it does exactly the same, goes from 1k to near stall and then back up again.
_________________
I checked the ICV though and it did what the Haynes manual said it should.
Gwynleym10
- Contact:
So did mine... but car dramatically improved when i put another one in!I checked the ICV though and it did what the Haynes manual said it should.
Hmm - okay, im beginning to regret the Haynes purchase.
Fought with the dash for an hour before realising the Haynes instructions on dash removal were for the 5 series.
Might try a new ICV
Might try a new ICV
smithy318i
Dash removal article... http://www.strictlyeta.net/technical/dashboard.html
I have a spare ICV somewhere. So ill try that one.
Thanks for that Smithy.
I managed to do it in the end but i swore a lot!
My 316i M40 has done this every day for the last 7 months of owning the car. Ive changed the rotor arm, dizzy cap, fuel filter, intake hose (split), Blue injection temp sensor, thermostat, ht leads and cleaned/gapped the plugs. Not specifically for this problem il say. Its made no difference to this problem at all
I tried another icv from a breakers and it was exactly the same. ive inspected the AFM for freeplay or stiffness but seems perfect. Kinda leads me to the only thing left to try.... ECU!
Note, i turned the emissions down 2 turns of the screw and this seems to have reduced the problem somewhat. Il stick the CO meter on it sometime see if its safe to turn down more, maybe il get more than 26 mpg out of this rattle box yet ;)
G/90 316i M40 tickety tic!
ST185 GT4
Archless! Tech 1 project
E46 330d Sport
ST185 GT4
E46 330d Sport
