m40 car has started stuttering.
at speed its ok but when u slow down and accelerate it stutters.
im thinking blocked injector ?
ht lead or rotor / dizzy cap ?
Car is Hesitating
Widge
Could be any of those, or an air leak in the bellows area, or the DME realy on the nearside wing. But I'm no expert the Guru Brian will be along shortly!!
m-dtech
- Unapproved Trader caution
car is doing my head in.
Widge
Sounds like a leak between the AFM and the TB TBH.
Gwynleym10
sounds like it needs an "italian tune" (that's 110+ on the motorway for 5miles...)
m-dtech
yeah wish it could do 110mphGwynleym10 wrote:sounds like it needs an "italian tune" (that's 110+ on the motorway for 5miles...)
320Touring
stuttering is likely to be down to a leak as widge said.
check all the boots on the afm for cracks or leaks
also have a quick look at the rotor arm for deposits and give it a clean.
m-dtech
timing belt slipped hence poor performance. luckily it didnt snap.
320Touring
is this the same m40 that you've had all the issues with?m-dtech wrote:timing belt slipped hence poor performance. luckily it didnt snap.
Widge
Wow lucky that wasn't fcuked then!
Gravy
Hehe, funny that! Because thats exactly how I cleared my motor out (well, was between 95-100mph) Can't do anymore without it sounding like its gonna blow!Gwynleym10 wrote:sounds like it needs an "italian tune" (that's 110+ on the motorway for 5miles...)
Alas, the problem is recurring...............here comes the conversion!!!
