How dirty should your oil get after 3,000 miles?
kevin316i
When I bought my iS, there was about 3k miles since its last service, and I got the car fully serviced as a precaution. I have since changed the oil after another 3k. In each case, the oil looks very clean,and I'm wondering if this is a good or bad thing. This might sound like a stupid question, but I have heard in the past that an oil is doing its job if its getting dirty, maybe this is a load of sh*t.
I had promised myself I'd change the oil and filter every 3000 miles, but when its very clean after 3k, maybe I'm wasting my money? The oil in my previous E30( a 316i) used to get more dirty.
placey
kevin
i change mine between 3-5k miles and it's always still clean. engine has done 48k now. i figure clean oil comes from clean engines.
paul
paul
i saw a doctor and she gave me some pills....
kevin316i
I'm inclined to agree with you Paul, think I'll keep up the 3000 oil service. It's not big money in the overall scheme of things.
stevetigger
Good ole BM's
My Vauxhall crap has black oil after 3K
If the oil is getting dirty then the 'fillter' isnt doing its job,
prob because its been on for too long
stevetigger
I dont care about it, I hope it bloody blows up soon!DanThe wrote:If the oil is getting dirty then the 'fillter' isnt doing its job,
Motorhole
Indeed, dirty oil shows a buildup of carbon and metal deposits that the filter is missing. Dirty oil means excessive engine wear. A well looked after engine will keep clean oil fora long time...even my "crappy" Pug 106 1.1i will keep its oil relatively clean over the 20,000 mile service intervals.
Dirty oil after 3000 miles, I would think, would be an indication of excessive engine wear and/or mixture problems resulting in excess carbon deposits. Your in the clear mate!
Zayyan
That's very modest Steve, not a 760iL?stevetigger wrote:I dont care about it, I hope it bloody blows up soon!DanThe wrote:If the oil is getting dirty then the 'fillter' isnt doing its job,
prob because its been on for too longThen I can get my E65 745i
My oil is black after 3,000 miles and it needs topping up a pint or so between oilchanges too - though with 196,500 miles I can't complain.
With your oil being clean at 3,000 miles I'd just follow the service lights as it tells you you need a change sooner if you drive it harder etc. Quite clever really.
Even the service light intervals are far more often than is really needed. Oils have come a long way since the M20 was designed.
M20B25, 200k+ miles, oil comes out (after red service light has been on a week or two) still nearly as golden as when it went in!
Project_E30
A bit off topic but what about Diesel engines as mine is changed every 5K and if always black.
Disgusting, smelly, carcenogenic muck should be banned outright for road vehicles, or at least confined to heavy ggods vehicles and banned from built up areas.Project_E30 wrote:A bit off topic but what about Diesel engines as mine is changed every 5K and if always black.
On the oil front, judging by the state of the oil in a 320D last week an hour after I had changed it, I should think about once a fortnight is about right!
Project_E30
Brianmoooore: I think you should check whats carcenogenic. You'll find its petrol. Doctors even rocommend not breathing in the fumes when filling up at petrol stations.Brianmoooore wrote:Disgusting, smelly, carcenogenic muck should be banned outright for road vehicles, or at least confined to heavy ggods vehicles and banned from built up areas.Project_E30 wrote:A bit off topic but what about Diesel engines as mine is changed every 5K and if always black.
Anyway, I'll keep changing every 5k
mrLEE30
A lot of the discolouring in oil also comes from the heating and cooling cycles, and this cycle is also responsible for the oil loosing its properties to lubricate (or actually its ability to form a thin film on metalic materials i.e. bearing points), so you will find you should change your oil more frequently in winter than in summer.
Here where it is as hot as uk summer even in winter most car dealers will not bother to change oil even for service intervals, as it is not required.
mrlee
mrlee
orangecurry
yes and no Prime MinisterProject_E30 wrote:Brianmoooore: I think you should check whats carcenogenic. You'll find its petrol. Doctors even rocommend not breathing in the fumes when filling up at petrol stations.Brianmoooore wrote:Disgusting, smelly, carcenogenic muck should be banned outright for road vehicles, or at least confined to heavy ggods vehicles and banned from built up areas.Project_E30 wrote:A bit off topic but what about Diesel engines as mine is changed every 5K and if always black.
Benzene is carcinogenic, 'petrol' is not.... but as 'unleaded petrol' is petrol with 5% benzene....
bring back safe and healthy 4* is what I say
Project_E30
orangecurry wrote:Thankyou for confirming my pointProject_E30 wrote:Brianmoooore: I think you should check whats carcenogenic. You'll find its petrol. Doctors even rocommend not breathing in the fumes when filling up at petrol stations.Brianmoooore wrote: Disgusting, smelly, carcenogenic muck should be banned outright for road vehicles, or at least confined to heavy ggods vehicles and banned from built up areas.
Anyway, I'll keep changing every 5k![]()
orangecurry
you are welcome
but don't forget, diesel is still 10 times more carcinogenic than unleaded petrol, so I'd say you lose the argument and once again Brianmoooore is the champion of... well everything.
Gwynleym10
He is very correct, read a lot of stuff about cyclist in london who breath diesel fumes and how it makes the insides of your lungs blead! hmm is cycle everyday and apperently masks do very little.you are welcome
But so off topic...
Surely is also depends on thte quality of the oil you put in?
I don't use much of that stuff either - mainly because of the detrimental effect on my wallet, than on my health.Project_E30 wrote:[
I mainly use LPG, which is why my oil comes out almost the same colour as it goes in!
Borrowed a diesel for a day once, and had to fill it up. Could feel the stuff coating my skin as I filled it, and could smell and taste the stuff all day.
Project_E30
So your saying Diesel is 50% Benzene (carcinogenic)??orangecurry wrote:you are welcome
check your facts!
