springs/shocks better then Mtech ones...
Dan318-is
no but i have some koni shocks on my turd outside, 46mm ones tht will go on urs! ( i think)
dark_sounds
koni's any good?? didnt someone say they bit harsh on the road??
Kos
the shocks you can, the springs differ in poundage, the 40mm drop in the sprin/street kits can make it too low at the back, so on my 316i i acdded m-tech springs from the IS to brig it up slightly.toby wrote:kos has a good pint here.Kos wrote:billies with proper springs, H+R / or the ones supplied by ECP in the street/sprint line kits. got them on the 316 and the IS
konis are ok, but a bit oo harsh for the roads??
"The Bilstein Streetline Suspension Kits Product code: BSK116
Bilstein Streetline Suspension Kit. Lowers by 40mm approx.
The Streetline kit consists of four Original Equipment (OE) Spec Bilstein Gas shock absorbers complete with lowered sports springs. This Entry-Level kit proves very good value for money. Ԛ£207.00 (inc VAT)"
http://www.europerformance.co.uk/pages/ ... ml?id=2966
Can you use the Bilstein Streetline Suspension kit on a touring ??- I'm assuming you can't
there is a similar thred to this one going on at the mo,
as a point of interest, i'm looking at KW springs at the mo.
Dan318-is
they are a tiny bit harsher i think, tim_s runs them on his daily an says they do the job tho!
will be a cheap set for all four tho and springs too!
Kos
KW list 55/35 for the IS, the do complte kits aswell.
Dan318-is
Ali you got PM
dark_sounds
tbh im just after a drop approx 40 mill from factory,,, and a smooth ride,, i dont want a bumpy sporty ride,,, its still my daily driver, but just want the pimpin looks.. unfortunatly theres no chance getting away with 60mm
well the boge 40mm's from gsf will be for u then, and at around Ԛ£60 won't break the bank!
