is it possible to get my exhaust manifold welded on my 320i its easy to get to the crack as its on top where the heat gaurd lies on top of manifold
on pot 3
welding exhaust manifold
kam-325i
You need to get someone that knows how to weld cast correctly. Dont just get someone who can weld with cast rods to do it, as it will crack again !!
thesaint
or get a second hand one from the breakers, thats what i did, cost me Ԛ£12, lot easier than trying to weld cast.
1986 325i - Gone. 1993 318i touring, m52 in the planning stages.
Templ8e30
To weld the manifold properly it needs to come off first. Cast iron has to be heated evenly before it can be welded with the correct rods then cooled as slowly as possible otherwise it will just crack again.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
robo
thanks guys !
yeh hear wot yr saying about heat transfer thru the manifold wen welding
needs to be off the car nd on the bench. maybee stick second hand one on as its coming off anyway.
thanks again
thanks again
steveoz32
Reminds me of my strifes with trying to weld my E36 M's flexy joint on the ns manifold. Little too high, blew a hole clean in it lol. Ended up chopping the bloody thing out and welding a solid pipe in, that's what ML recomended me to try anyway, seemed to work.
But yeh, for all the trouble of trying to fix up the cast (never very succesful long term IMHO, get a S/H one, cast manifolds are cheap as chips because no one wants them.
Jon_Bmw
- Dangerous when thinking
Yeah the procedure is what iain said, but you may as well replace the manifold. When you do please use new studs and bolts, they are only about Ԛ£2 for the lot from the dealers. I happen to have an m20 manifold spare
