accelerator pedal removal to get carpet off
dark_sounds
Post Thu Mar 09, 2006 12:14 pm
as above please :)
how do i remove the carpet around the accelerator pedal?? basically how to remove the pedal to get to the carpet
cheers :)
JimmyC
Post Thu Mar 09, 2006 12:17 pm
You can just inclip the top and lift over- easiest way I think
dark_sounds
Post Thu Mar 09, 2006 12:34 pm
meh raining now will give it a go later..
cheers
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri Mar 10, 2006 12:55 am
i would of done it wed's if u had asked mate its easy, theirs a few slip on clips at the base of the pedal.
Remoe the eclip fromt he acel post and slip the pedal off then u r laughing mate
Post Fri Mar 10, 2006 9:07 pm
The accelerator pedal is officially unreuseable if it's removed, but in practice, if you can twist it out undanaged, then it can be reused
jonbuoy
Post Fri Mar 10, 2006 9:17 pm
Just cut the carpet you woose! :D
It's about 3 inches to cut toward's the bulk head! You can't even see it :mad:
You don't want Brian to be right about your throttle mate, might need a throttle to go along :D
Post Fri Mar 10, 2006 9:31 pm
jonbuoy wrote:Just cut the carpet you woose! :D
Nah, you can still drive it OK with all the plastic pedal off the car. Frequently do if the carpets out of a car for leak checking.
dobbie82
Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
Post Fri Mar 10, 2006 9:52 pm
the pedal isnt properly attatched on my 318i... nowt to do with the carpet, I'm just too lazy to go out in the rain to fix it.. drives fine!
oze30
Post Mon Mar 13, 2006 11:05 am
depends which pedal you have. I went looking for when mine busted ( tryied to maneauver the carpet around the pedal, and Yoink! tore the flexi plastic bit off it! You can get to it with a smaill flat blade screwdriver, push in near the edges, you feel a row of one or two holes. Push the driver thru these holes and wiggle the pedal. IT SHOULD come off.. if you have the female style of pedal. If you have the male style.. I got no idea!
dark_sounds
Post Mon Mar 13, 2006 11:17 am
cheers pedal aint an issue anymore though carpet still not coming out,,, think the heater block thing is not letting it come out! anyway cant do anything now,,, tech2 sitting on it.
Post Mon Mar 13, 2006 7:54 pm
dark_sounds wrote:cheers pedal aint an issue anymore though carpet still not coming out,,, think the heater block thing is not letting it come out! anyway cant do anything now,,, tech2 sitting on it.
Cut around that piece with a Stanley knife - standard practice.
Don't cut the wires under the carpet!
Bigsidney
Post Sun Apr 02, 2006 11:00 am
Hi M8 in regards to the carpet being hard to remove, the problem being is the brake actuator rod runs from one side of the car to the other from the pedal box to the mechanisim for the master cylinder on the passengers side to get the carpet out/back in you have to remove this rod there are three clips to remove 2 on the drivers side which disconnect the brake pedal and one on the passengers side then this is the tricky part , unscrew the rod from the drivers side and pull it towards the passengers side this makes it so much easier to remove and refit the carpet correctly as it is a bitch to fit back under the heater box with this still in place, make sure you mark the postion of the actuator rod locking bolt on the drivers side to ensure correct adjustment when refitting.
The throttle pedal is an easy one there is a circlip at the top of the pedal remove this and pull the pedal towards the door thus removing it from the linkage this will then enable you to slide the carpetr towards the rear of the car for removal
Hope this helps you out M8 as I have just had mine out to weld the sills and back arches on mine
Rav69
Post Wed May 10, 2006 2:11 pm
[quote="Bigsidney"]. The throttle pedal is an easy one there is a circlip at the top of the pedal remove this'
Whats the handiest thing to use in order to remove the circlip?
Bigsidney
Post Wed May 10, 2006 6:55 pm
A small screwdriver will prise off the circlip and you pull the pedal to the left off the pedal mount thus letting you pull up the carpet[/quote]
