Thanks Dude, thats what i wanted to know.kam-325i wrote:You can get two types of arms, one for ABS and one for Non-ABS. The difference being is that the ABS one has the hole for the sensor. The ABS sensor picks up of the driveshaft.
Where the wheel bolts on will be the same.
The only problem i could see you having is if there is a difference in bearings for a Non-ABS driveshaft over a ABS driveshaft.
