Symptoms:
Driving home today, I couldn't shift into 2nd coming up a hill, so I shifted into 3rd, and made it to a crossing, where I went into 1st, and as I was letting the clutch out, the peddle was vibrating, ala an ABS pedal, back up my foot. Got into 2nd with some diffuculty, but 3rd and 4th were fine.
Now at a stop, all gears are easy to select, and the vibrating peddle has disappeared.
2nd is still crunchy, but able to be selected after a bit of effort.
Possibly of interest:
Now, in June 04, I have receipts for my flywheel being machined, and my spigot bearing bearing replaced, and new clutch, pressure plate and release bearing being fitted. At the same time, my slave was leaking, so it was sent away for resleeving and rekitting.
Currently:
There has been no trouble with the system up until now, so what do you think could be causing the reluctance to shift into 2nd on the move, but not at a stop. My peddle travel is also the same as yesterday too.
Thanks in Advance,
-Ray
Clutch / gearbox woes
Templ8e30
Worn synchro rings in the gearbox is my opinion on the shifting front, 1st and 2nd seem to go first.
I seem to remember someone saying that the synchro rings are no longer available. A gearbox rebuild will be costly anyway so I'd get a good second hand box.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
CiLK_WuRM
I'm thinking broken pressure plate fork, will know when I jack it up tomorrow
