inlet manifold and injector help please
andy325
Post Thu Mar 09, 2006 1:05 am
hi all
can anyone tell me if the early 325 and later 325 had the same inlet manifolds?
can anyone tell me if the early 325 and later 325 had the same fuel injectors?
is a 320 inlet manifold the same as a 325 inlet manifold?
i have a early 325 sport mtech 1 and thinking of swopping for the later type motronic so from my understanding i need -
crank pulley and crank sensor
wiring loom
ecu
is this right or have i missed something
kam-325i
Post Thu Mar 09, 2006 1:14 am
As far as i know, all the 325 engines were the same apart from a difference in comprestion ratios for early/late models....
I dont think the 320i intake manifold will fit on the 325i.
andy325
Post Thu Mar 09, 2006 1:19 am
from what i know my car has motronic 1.1 as did all early 325's and the later cars had motronic 1.3
it is this motronic 1.3 i wish to convert to and just wondered how much work it was
kam-325i
Post Thu Mar 09, 2006 1:24 am
i cant really seeing it being much work, the hardest bit being changing the loom part from the engine connector to the ECU and the engine loom....
Dont know of many people that have done a 1.1 -> 1.3 upgrade on a M20B25
kam-325i
Post Thu Mar 09, 2006 1:42 am
I have just looked at the part numbers for the 325i ECU, and there appears to be 7 different ones......
325i 2.5 litre (M20) 85-87 Bosch Motronic ML3.3 0 261 200 073
325i 2.5 litre (M20) 85-87 Bosch Motronic ML3.3 0 261 200 081
325i 2.5 litre (6 cyl) 87-88 Bosch Motronic 1.3 0 261 200 164
325i 2.5 litre (M20) 88-90 Bosch Motronic 1.3 0 261 200 173
325i 2.5 litre (M20) 90-92 Bosch Motronic 1.3 0 261 200 380
325i 2.5 litre (6 cyl) 89-92 Bosch Motronic 3.1 0 261 200 402
325i 2.5 litre (6 cyl) 89-92 Bosch Motronic 3.1 0 261 200 403
They dont make it easy do they.........
