Touring Rear Wiper Motor
StuBeeDoo
Post Tue Mar 07, 2006 10:28 pm
My rear wiper is leaking water into the tailgate.
Is there a replaceable seal/o-ring, or do I have to shell out for a new motor?
TIA
Stuart.
Andy335Touring
Post Tue Mar 07, 2006 10:45 pm
I've not had mine apart but theres a gromet showing on the ETK ?
http://www.upload2.com/?cmd=_viewer&fil ... pg&s=3947e
StuBeeDoo
Post Wed Mar 08, 2006 10:15 am
Thanks Andy, I saw that one too. I think it's the one that seals the glass where the shaft comes through. Mine is actually leaking water out of the motor, so there has to be some kind of seal inside.
Cheers anyway
Stuart.
tourer-dan
Post Thu Mar 09, 2006 12:30 am
The washer pipe connects to the back of the motor just like a normal washer jet push fitting. The fixed motor pipe runs straight throught the centre of the motor out to the nipple on the outside. It's probably the pipe connection which is leaking, otherwise the motor pipe itself is split, which I'd doubt.
