i need help
robo
I have a 320i auto h plate got a problem with cutting out it only seems to occur when the engine is hot, sometimes the engine will restart and sometimes not
i have replaced the airflow meter and the ecu computer with no avail the fault is still occuring if any of u nice people can please help it would be much apprieciated thank you
eko
- Old timer
Blue temp sensor?
Idle control valve?
Idle control valve?
optima
next time it does it feel your coil if its hot i could be breaking down
