ANOTHER obc question
Cloggy Saint
Post Tue Mar 01, 2005 9:16 am
Is this actually the coding plug or just the slot for it?? Also, the unit is from a 325. If this is the code plug, is it worth shelling out for a 2.0 version or will the readings be near enough accurate?
thanks.
Davenotouring
Post Tue Mar 01, 2005 10:38 am
That is the coding plug there mate.
The 2.0 and 2.5's have very similar economy, and it's not 100% accurate anyway, I wouldn't change it. Ԛ£40 at the dealer :eek: :)
BMW 328i Cab - Daily Slag
Cloggy Saint
Post Tue Mar 01, 2005 10:45 am
Cheers Dave, and thanks for the advice on fitting the loom etc. I'm nearly there now, just the relay box to fit and hopefully that'll be that.
Davenotouring
Post Tue Mar 01, 2005 12:00 pm
No problem at all.
The relay box is easy, two screws onto the top of the same bracket which the ECU sits on.
Good work!
