cambelt 325i
thesaint
Post Thu Mar 02, 2006 12:29 am
thinking of a cambelt chnage, is it an easy job, anthing else i should change while im at it?
1986 325i - Gone. 1993 318i touring, m52 in the planning stages.
Post Thu Mar 02, 2006 12:43 am
Easy enough if you're at all mechanically competant.
Water pump should be changed at the same time, and belt tensioner pulley of course.
Distributor cap and rotor have to come off, so check them as well.
Don't strip the thread of the small long bolt that fixes the belt cover to the head.
thesaint
Post Thu Mar 02, 2006 1:56 am
thanks for that, already done water pump 10,000 miles ago
Post Thu Mar 02, 2006 9:01 am
thesaint wrote:thanks for that, already done water pump 10,000 miles ago
In that case, the cambelt should have been done as well.
You didn't re use the old one did you?
thesaint
Post Thu Mar 02, 2006 8:26 pm
was in a hurry and dint have a spare cambelt it looked good, but it worries me endlessly
Post Thu Mar 02, 2006 8:33 pm
do a search for a thread called "Cambelt change Idiots Guide" it chronicles the belt change i did last summer and has links to a guide with pics etc. I had never done a job like that before and I pulled it off
kam-325i
Post Thu Mar 02, 2006 9:02 pm
I am dreading doing mine........
Adammcf
Post Thu Mar 02, 2006 9:27 pm
Its a piece of piss. Just make sure the notch on the crank lines up with the notch in the belt cover and the notch on the cam pulley lines up with the notch in the head. Then turn it a few times by hand once its all fitted to make sure nothing is catching and to make sure it still lines up after a few turns.
Dan318-is
Post Thu Mar 02, 2006 9:29 pm
Adammcf wrote:Its a piece of piss. Just make sure the notch on the crank lines up with the notch in the belt cover and the notch on the cam pulley lines up with the notch in the head. Then turn it a few times by hand once its all fitted to make sure nothing is catching and to make sure it still lines up after a few turns.
This is extremely important; i found out the hard way on a 320i turd at college that is now in e30 heaven (well hopefully it went to hell)
thesaint
Post Thu Mar 02, 2006 9:31 pm
will do tomorrow if the dealer has the parts in stock
kam-325i
Post Thu Mar 02, 2006 9:41 pm
The last time i changed a cam belt, i managed to get it wrong, God knows how i got it 180Deg out....This was on my Cortina.
Do you have to take the bottom belt cover off ? the one around the bottom pulley.
eun
Post Fri Mar 03, 2006 1:43 am
i need to do mine soon as i dont have a clue when it was
last done as i bought the engine from someone and i wanna be safe
than sorry
i got quoted Ԛ£300-Ԛ£350 is this expensive? :?
im not very mechanically minded, i would probably feel more confident paying brianmooore to do it as he gives more info than a specialist :mad:
DaveD
E30Zone Wiki Specialist
Post Fri Mar 03, 2006 7:32 am
My mechanic has just done (i am a lazy sod)mine and had great trouble getting that big nut off the front of the crank...it had seized on.so have the right equipment ready
Ant
Retired Team Member
Retired Team Member
Post Fri Mar 03, 2006 8:41 am
no need to take the "nut" off fella
makes me wonder WTF goes on when I read stuff like that !, talk about making it hard work :lol:
eun
Post Fri Mar 03, 2006 10:52 am
ant wrote:no need to take the "nut" off fella
see this is what i mean with garages ripping you off! if its a simple job
for a zoner id rather give my hard earned cash to them.
my car has no history anyway so its not like id be devaluing [sp] it :mad:
Post Sat Mar 04, 2006 12:10 pm
gcorky
Boost Junkie
Post Sat Mar 04, 2006 1:09 pm
300-350 id do 3 for that at proper rate...lol
:eek:
525 sport
Post Sat Mar 04, 2006 2:23 pm
If you're offering Ԛ£350, I'll be right down.
Post Sat Mar 04, 2006 2:25 pm
DaveD wrote:My mechanic has just done (i am a lazy sod)mine and had great trouble getting that big nut off the front of the crank...it had seized on.so have the right equipment ready
Yee Gods!!!!! FIND YOURSELF A NEW MECHANIC!
