[Rant] Thoroughly f@~ked off that I've wasted time & Ãâ
Templ8e30
Post Thu Mar 02, 2006 8:13 pm
I've just fitted an E36 steering rack to my e30, I bought the pipe kit from Ian332isport and got hold of an E36 rack from the breakers for Ԛ£40.
I spent all yesterday afternoon fitting it which was relatively easy but I ran out of light so I resumed today which involved fitting the return pipe and bleeding the system.
This is where it all went Pete Tong.
After filling I bled the system and found 2 leaks, one at the return pipe banjo bolt and the other from the flexi hose in the pipe kit. I tried repeatedly to tighten the olive nut on the flexi but found that it was actually coming from the swaged joint so I couldn't do anything with that one.
I went to tighten up the banjo bolt to stop the other leak and found that the thread in the rack was completely stripped. B@stard.
I need the car for work tomorrow so I was left with a knackered rack and a faulty pressure hose so I lost my rag with it ripped it all out and proceeded to smash seven shades of sh!t out of the whole assembly with a 10lb sledge hammer :x . That felt much better.
So I've refitted and bled the old e30 rack and that's the way it's gonna stay.
F@ck the rack conversion, it's cost me Ԛ£90 and 2 days of my time faffing around with it to no avail.
I'm off to have a shower and think of all the other things I should have spent my money on :cry:
In a word : BOLLOCKS !!!!
[/rant]
Iain T
2007 Mazda 6 2.0 estate
Demlotcrew
Post Thu Mar 02, 2006 8:47 pm
Mate, that made me laugh! (sorry)
Andrew
E30Adam
Post Thu Mar 02, 2006 8:50 pm
If you'd driven a car with the conversion then I think you'd have percivered with it. The difference is phenominal.
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
Dan318-is
Post Thu Mar 02, 2006 8:52 pm
Wish this would work on an Is :(
bmwe30mtech
Post Thu Mar 02, 2006 8:54 pm
Not a huge loss. Not too long untill you will look back and laugh at your misfortune. :)
Paul
E30Adam
Post Thu Mar 02, 2006 8:56 pm
318-is wrote:Wish this would work on an Is :(
It will.
TheDutch
Post Thu Mar 02, 2006 8:58 pm
It will.
It wont.
jonbuoy
Post Thu Mar 02, 2006 9:00 pm
Why do you think this won't work Dan?
Dan318-is
Post Thu Mar 02, 2006 9:02 pm
I know it wont work;
the manifold on an Is is tubular and very well designed from the factory. The Dutch (above) on here tried it on his IS an it did not work; it would not clear the manifold; also, even with aftermarket manifolds, (if you can find one), the clearnance between the rack and the manifold itself is so small its unnacceptable
Cotty
Hartge Crew
Post Thu Mar 02, 2006 9:04 pm
Templ8e30 wrote: I lost my rag with it ripped it all out and proceeded to smash seven shades of sh!t out of the whole assembly with a 10lb sledge hammer :x . That felt much better.
Its funny how good it makes you feel
E30Adam wrote:If you'd driven a car with the conversion then I think you'd have percivered with it. The difference is phenominal.
What is the difference, less turns lock to lock? or better feel?, more contol? :?
jonbuoy
Post Thu Mar 02, 2006 9:05 pm
Bloody hell geese :(
I thought it would work on any E30 as TOURINGDADDY has put an M3 rack on his 325i Tourer and did'nt need to change the pipe's either, just moved the rack forward to accompany the original pipe's :cool:
jonbuoy
Post Thu Mar 02, 2006 9:07 pm
3.2 turn's lock to lock :D
Martinaston
Post Thu Mar 02, 2006 9:23 pm
Templ8e30
I don't want to tell you how to work on a car as you sound like you know your stuff (and i'm being nice because i want to pick your brain at some point on how you re-built your diff :) )
But, evo-stick hard and fast would have cured the leaking pipe (even if only temporary) and did you fit new crush washers with the banjo ?
You only have to loosen them and re-tighten them for them to leak (there shit) but only cost a few pence.
I need to do mine at some point, especialy after last week when i used the car after driving a van with 3 turns lock to lock all week, i backed out the garage and turned 1 1/2 turns as if i was in the van and proceded to drive straight into the wall :mad:
Stick with it it's got to be worth it in the end 8)
There is NO nucleus.
Cotty
Hartge Crew
Post Thu Mar 02, 2006 9:46 pm
Scuse my ignorance but what is standard lock to lock. I cant remember as i just put my palm on the wheel and spin it
Dan318-is
Post Thu Mar 02, 2006 9:47 pm
4 turns lock to lock with p/steering, 4.4 without
TheDutch
Post Thu Mar 02, 2006 9:50 pm
Cotty180 wrote:
jonbuoy wrote:
Cotty180 wrote: What is the difference, less turns lock to lock? or better feel?, more contol? :?
..and spin it, and spin it, and spin it, and spin it, and spin it, and spin it just over 4 turns lock to lock for PAS.
Even 3.2 is not that quick, many run of the mill cars have under 3 turns lock to lock. I got my old car down to 2.2, that was great except for having to manually cancel the indicators all the time.
Cotty
Hartge Crew
Post Thu Mar 02, 2006 10:21 pm
318-is wrote:4 turns lock to lock with p/steering, 4.4 without
I have power steering, would having less turn lock to lock make any difference to the strength/power needed to turn the wheel :mad:
Templ8e30
Post Fri Mar 03, 2006 3:06 pm
Martinaston wrote:Templ8e30
Hi, I did use new seals on the banjo's. The problem was the thread had stripped out of the rack so I couldn't tighten it.
I'll try again this summer probably, and try to use the original hoses rather than the pipes that I bought (they're well battered now :roll: ).
Ho hum, another lesson learned :mad:
Iain T
Geeman
Post Fri Mar 03, 2006 3:16 pm
Question: Why do you need to buy the new, modified pipes, if the old ones would have fitted anyway...? Me being stupid and all...
billgatese30
Post Fri Mar 03, 2006 6:04 pm
oh well iain, not to worry at least you managed to vent some anger :roll: :cool:
bigkev
Post Fri Mar 03, 2006 6:47 pm
i think you should post picks of the mangled rack for full effect :D
oze30
Post Fri Mar 03, 2006 7:57 pm
winkeye @ bigkev
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sat Mar 04, 2006 12:35 am
There is a moral to this thread always put the sledge hammer away before working on your car. :twisted:
Sorry it didnt work mate, i had heard good things about the e36 rack
Neil
topspark
Post Sat Mar 04, 2006 4:17 am
Iain,
E36 curse , its cos your misses has gone over to the dark side !!!
winkeye winkeye
lee
1989 SCHWARZ 320i SE , 4 DOOR!!!!
You say the magic's gone,Well i'm not a magician
You say the spark's gone
Well get an electrician..........
Templ8e30
Post Sat Mar 04, 2006 10:44 pm
topspark wrote:Iain,
winkeye winkeye
lee
Don't you just know it :roll:
You can't see the little bits of ally all over the patio because of the snow but there are lots. The rack is bent like 'nana too :twisted:
Giles, I was under the impression that the E36 pipes would not fit. I still reckon the 6 pot pipes won't because when I fitted this rack I used a 4 pot e36 return pipe that doesn't have the ' oil cooler' part in it and it only just squeezed in between the rack and the sump. Also I'm pretty sure the e36 return pipe is too short to reach the reservoir and is also points forwards instead of upwards. Not an easy pipe to bend without kinking it.
Maybe I'll attempt it again in better weather and with another rack, strangely I get the impresiion that this rack is no longer oil tight winkeye
Cheers,
Iain T
