Post
Tue Mar 01, 2005 7:06 am
Hardly exotic!!! b ut very warm and belive me the E30 radiator system is not up to the job, in summer when sitting at lights in the cab, outside 50degress, balck car, A/C on so the electric fan comes on, new viscuos coupling and the only way to stop the beast from soaring high into the red is to set temp controls to hot and full fan!! not pleasant!!!!
will this surely is a good excuse to strip down your front end to clean and take pictures!!! or if you are real nice just whip off the headlight surrounds, kidney surrounds and get a snap shot from the front, pretty please!!!!
by the way for everones info Mitsubishi do a high temp coolant which after much experimentation is by far the best stuff for high temps (above 30) it comes in a litre can and opens like a tin of beans, mix with two parts distilled water and works better then others!!
pretty please will6pot!!??
mr lee
