im gonna put a 3.91 slipper intp my iS at the weekend
i'll be doing it at work on my ramp, but i need to know what i have to do to make the large case slipper fit into my car that originally had a small case diff...
do i need the drive shafts from a 325i aswell or will my ones suffice???
any help is appreciated
i know tim_s has got a 3.91 slipper in his...
small case diff swap for large case diff swap HELP
stuartgallafant
kam-325i
There is some fudging to be done with the driveshafts, but i cant remmember what it is...
Lordschleife
Cheers,
Robin
Robin
Dan318-is
The propshaft needs to be shortened.
Its in two parts and should shorten by pushing it toward the engine if you understand?
Simple stuff stu im sure you'l figure it out!
