very strange problem e30 325i 1990 G Reg
rajakhan
Post Thu Feb 23, 2006 9:36 am
Car seems to over fuel
crank it starts then cuts out,
crank again nothing
now confusion time
remove fuel pump relay and crank it and then it starts, then cuts out again,
replace relay and crank again with some eazy start in the throttle body and slightly rev it and then it idles, then when you restart it later again back to same problems, cranks not firing up.
why I say overfuel, plugs are wet when I open them up, any one know a solution to why this starting and overfueling is occuring?
Andy325i
Post Fri Feb 24, 2006 6:13 pm
Is it just when its cold? can you get it running ok when warmed up? where abouts are you?
Andy
rajakhan
Post Fri Mar 03, 2006 2:56 pm
in london mate, cold or warm, one start and then cuts out and crank n cranks and nothing, :cry:
rajakhan
Post Mon Mar 06, 2006 10:53 am
sprayed more eazystart and cough and then its okay, so cold start problem, could it be a cold start injector playing up? any help?
