hello guys
got one for you, ive got a pair of T1-R's and T1-S's, what would you say is the best way to have them on the car...
eg. T1-R pair at front and T1-S at back or vice versa
i want good grip, but also wouldnt mind a bit of slip at the rear...
cheers
Toyo T1-S and T1-R advice
- orangecurry
I doubt whether anyone in the history of the world is in a better position to tell us the answer, than YOU
why don't you try it both ways for a week each time, and then let us know?
- Contact:
If it was me, I'd have the t1-r on the rear
a) they're likely to be newer and you're supposed to put the newest tyres on the rear
b) I think the t1-r looks like it has more channels cut in for water to escape? I may be wrong but if so and it's a better tyre in the wet against eg. aquaplaning then I'd want them on the rear
Of course if the t1-r are far more worn than the t1-s then I'd put them the other way round with the t1-s on the back
Out of interest, how do you rate the tyres overall and compares to each other, particularly in the wet?
Cheers,
Robin
Robin
yeah good point from orange curry...
well i got the t1-s fitted to the rears yesterday and t1-r remain at the front, t1-s are brand new and t1-r are about a month old, first impressions are really good, plenty of grip everywhere, in the dry that is, not had a chance to try in the wet.
I dont really think there is much difference between them, but the t1-s look wider on the rim because of their tread pattern so i think im going to keep them at the rear.
325i Touring
Hi, don't know if this will help but I had a chat with a Toyo technical rep at the Autosport International show in January. He told me that the T1 R is the newer tyre and uses different technology to the S. The carcass is manufactured in a fully laden profile which is designed to put more tread on the road particularly when cornering. Both tyres were on the stand and the obvious difference is the T1 R has block treads on the outside edge and the tread depth appears to be greater. It was a nice soft compound too. I found all the Toyo guys really helpful, so if you need any further info try: www.toyo.co.uk or e mail: info@toyo.co.uk
thanks alex, might get in touch with them.
lordschleife - in general i rate the t1-rs really well, i had a pair of kumhos on the rear a while ago which were good in the dry but not as good in the rain as these toyos (t1-rs), and because of their soft compound they are really quiet. grip level is pretty awesome in dry and very good in the rain.
im basicaly gonna try the t1-s and t1-r eacy way for a week, ill let you guys know how they compare.
cheers
cheers
325i Touring
wouldn't it make sense to put the newr more treaded tyre on the front as that axle does the most?? (Braking/steering)
To me.. having more tread in the ass end will push too much into corners rather than steering. It's easier to counter a tail flick than front end push ( over/understeer.. i forget which is which)
all of the tyres are new.
but i know what you mean, i personally prefer oversteer to understeer, but of course the best setups are neutral.
325i Touring
