Hi guys, i'm new to this forum and must say, sooo happy to have found it!!
I use the bmwcc forum which is fantastic but this was recommended after a recent query I had.
Anyway, here's my prob:
Got a 1989 318i and spent a lot of time and money on it and goes ok, but i'm having a BIG problem with it starting either from cold or after its been sitting for bout an hour.
I put a spankin new starter in it and that makes it start first time but it just turns over for ages (8-10 secs). Then when it starts it chugs with a bit of grey/black smoke for a bit (almost like its clearing its throat!), then runs sweet!!
It got a 2nd hand AFM and a 2nd hand ICV about 4 months ago, but i can't remember if it was this bad before!! See the car had probs so a lot got done at the same time.
Any help appreciated, Geo1400
318i M40 just hates the cold start!!
Ant
- Retired Team Member
get a new coolant temp sender and fit that before you try anything else.
the blue unit is for the ECU
the brown is for the cluster.
update once you've swopped it dude, normall fixes 99% of these issues, get a NEW one though,, second hand is a false economy
Email FTW
Gwynleym10
yea they are only about Ԛ£11 from www.eurocarparts.co.uk or www.gsfcarparts.com
On m40 engines the blue one is located on the side of the engine underneath the airflow meter/bellow (remove this)
Welcome to the zone!
geo1400
Thanks guys, gonna try that tomorrow!!
Will let you know, Geo1400
Grantley
As above really, I had the blue temp sender go on mine making the car a b@stard to drive. The peeps in the know on here suggested changeing it and the differance was instant, These boys know there onions and welcome to the zone dude !
jonbuoy
As Ant said, he is the man to ask
I changed this not so long ago and everything was so sweet after
Little bit awkward to get to and to see but it's directly under the inlet on the block on the passenger side.
You need to get the AFM out the way and release the long black box that hold's the engine loom in place, this is bolted on right next to the starter motor.
Good luck mate
Good luck mate
Gravy
Is it worth changing the brown sensor too or is it only the blue one that usually causes the problems?ant wrote:get a new coolant temp sender and fit that before you try anything else.
I have to do this fix too and am just about to order......
jonbuoy
Just the blue one mate. That's the sensor that send's info to the ecu, the brown is just for the temp gauge.Gravy wrote:Is it worth changing the brown sensor too or is it only the blue one that usually causes the problems?ant wrote:get a new coolant temp sender and fit that before you try anything else.
Gravy
Cheers mate - My gauge works intermittently, most the time is just sits at the same reading (just outside the blue range) however long the car has been running, but occasionally it flickers all over the place and then goes back to the position mentioned above. I get appauling economy - so the blue sensor should send the correct info to the ECu, do i need the brown one to fix the flickering gauge? Or do you think it will settle to a normal reading once a new blue sensor is installed?
Thanks alot for your help
Rob
Rob
jonbuoy
Change the blue one first to see how you get on, it may settle but no gauranties. If it still happen's then there could be a cheaper option to try first and that's to tighten the bolt up on the back of the temperature gauge. These, for some reason, become lose after a while and can resolve a head ache of a problem. The awkward part about it is getting the dash out, it's not that hard, just a pain.Gravy wrote:Cheers mate - My gauge works intermittently, most the time is just sits at the same reading (just outside the blue range) however long the car has been running, but occasionally it flickers all over the place and then goes back to the position mentioned above. I get appauling economy - so the blue sensor should send the correct info to the ECu, do i need the brown one to fix the flickering gauge? Or do you think it will settle to a normal reading once a new blue sensor is installed?
Rob
Gravy
Awesome mate - the blue sensor is ordered, I look forward to the difference it ought to make to the way the car runs!
jonbuoy
geo1400
Well seen haynes don't give you guide lines on how to access the sensor on an M40, its like the bloody crypton factor!!
Anyway, sensor is fitted and on first start I would say it was 20% better, I did drain a bit of the coolant so got to give that time to circulate. I started it again after bout half an hour and def a bit of improvement.
So need to give it the ultimate test in the morning, will let you know!!
Thanks again Guys, Geo1400
