320i idle unstable!
m3mpower
Post Mon Feb 20, 2006 10:05 pm
hi i have a e30 320i se, when the car is stopped with engine on, the idle goes from 900 down to 600 rpm, and vice versa.
any idea what this is?
rare
Post Tue Feb 21, 2006 12:44 pm
Im having idle problems to. My car is idling far to high especially when cold, its up to as much as 1800 rpm in some cases. This only started happening recently, I think i may have confused the ICV when I took it off and cleaned up some of the crap inside it , obviously this was not a good thing to do as now its proper confused lol. It dont seem to be quite as bad when its warm though, but it still miss behaves in trafffic. If I dab the pedal in traffic sometimes it settles down, so Im going to see if the cables need cleaning/some lube.
I would imagine your situation is pretty similar? If it is, then im pretty sure the ICV is to blame! Its a bit delicate! Im going to put some carb cleaner through it later, if not I might just buy a new one though they are quite expensive.
Have you done any work to it recently? Touched anything? Or has it always done this. Maybe you have an air leak somewhere.
m3mpower
Post Tue Feb 21, 2006 7:05 pm
i have replaced the idle control valve recently ( with a second hand one ), it became slightly better but still not perfect..
i was thinking to clean the idle control valve inside with fuel but i'm not sure if its a good idea...
