wheel wobble when braking ?
exup
Boost Junkie
Post Mon Feb 20, 2006 7:04 pm
Hi
i 've got a problem with my winter hack ( E28 525e ), I ve just got it up and ruuning , stuck a 731 head / 325 cam and inlet track on it ,
but its got the 50 mph , wheel wobble, really bad,wheel balance is ok , so assume its worn bushs?, which ones to do first ? / how to test them ???
does any know of a good e28 site i could look for answers , seem to remember readying that although rubber bushs look ok they soften with age , leading to wheeel wobble etc ???
orangecurry
Post Mon Feb 20, 2006 7:11 pm
:mad:
is the wobble at 50mph, or when you brake?
If it's braking as per the title, I'd look at the brake discs first
apart from that I know nothing about the E28 and I'm just wasting space typing this :D
parksie
Post Mon Feb 20, 2006 7:52 pm
I think that if the wobble is ONLY at 50mph then discs prob OK
I suspect the thrust arm bushs, replace with a poly bush instead of original.
It worked for me !
