klu99apm wrote:Ok final question for today about this topic hopefully!
I think the wiring for the temp sensors goes through the plug in the photo. So I wanted do give it a clean and spray it with some silicone afterwards...
How does it come apart? I can turn the plastic collar underneath but can't seem to pull it apart. Do I need to pull harder or does it twist or something? (Its not the problem as the guage works fine on petrol but its bugging me thats all
Thanks again!
You may have found the answer to your problem! Didn't think about that socket when I answered the PM, but the common feeds to the injectors and the temp gauge wire do go through here.
Aconstant 12V supply will be present on two pins in this connector, but not when on LPG.
Wonder if there is corrosion in this connector that is causing this voltage to leak across and affect the temp gauge readings.
The connector is similar to the diagnostic connector in construction.
Twist the knurled part of the socket anticlockwise and pull apart at the same time, downwards. The plug will be left fixed to the black metal bracket, held in place by a lockring
