V12 meets E30 Touring
Jimbob
Thu Feb 16, 2006 10:57 pm
glenn wrote:was going to use an extra large e30 radiator that dips supplied but the top outlet was up against the nearside distributor, so we're now using the e32 radiator, so the front chassis legs have had to be modified to accommodate it.
What rad is that e30 one? :?:
dips346
London Meets Main Man
Thu Feb 16, 2006 11:00 pm
its one i got made for one of my v8 its longer about 6" in drop
glenn
Engine Transplant Services
Thu Feb 16, 2006 11:04 pm
not sure what it's off jim, i'm sure dips may shed some light on it.
it's nearly twice as thick and goes about 5" below a std e30 rad.
i'm guessing it holds about twice the coolant a std e30 rad holds
ian332isport
Fri Feb 17, 2006 1:06 am
Glenn,
I have E32 750i wiring diagrams if you need them :cool:
Ian.
glenn
Fri Feb 17, 2006 6:53 pm
ian332isport wrote:Glenn,
Ian.
you have pm ian.
e30_singh
Fri Feb 17, 2006 8:18 pm
hey that looks great....must shift like :mad:
just wondering where i can hold of some parts from a 8series?
and other larger engine bmws. i can find stuff on ebay all the time... but nothing serious like this...
whipsey
Sun Feb 19, 2006 8:03 pm
looks good i'm glad someones actually doing what i've been on about for a while looks like i'm getting the welder out this week to start sorting out my shell keep up the good work has much had to be fabricated for this as i'm kinda jumping in at the deep end here?
glenn
Sun Feb 19, 2006 8:28 pm
whipsey wrote:looks good i'm glad someones actually doing what i've been on about for a while looks like i'm getting the welder out this week to start sorting out my shell keep up the good work has much had to be fabricated for this as i'm kinda jumping in at the deep end here?
engine mountings, all four downpipes, the bulkhead where the servo sits has had to be moved about 3" to the nearside to miss the inlet manifold.
pretty much all the usual things you would expect.
Sun Feb 19, 2006 11:50 pm
glenn wrote: , and the bar that links the pedal to the servo.
Try an E34 one
E30Andy
Wed Feb 22, 2006 7:59 am
:clin: :mad: Were do i get me one of those? :mad: :clin:
Thats just awesome.
I wait with baited breath for updates...
Andy
glenn
Thu Feb 23, 2006 6:43 pm
going for a engine and gearbox dummy-fit this weekend while we wait for parts to come from the 'fatherland'.one of the parts i got was inlet manifold gaskets, Ԛ£75(+vat) each, and there's 4 of them 8O
engine/ box has to be fitted together and has to go in from underneath.
there's not enough room to tilt the engine enough to put the box on seperatly. the small shape of the tunnel and the large shape of the bell-housing mean's the gearbox cannot be withdrawn far enough off the clutch,without fouling on the tunnel
:mad:
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Thu Feb 23, 2006 7:05 pm
Glenn, amazing, full stop :)
Dips, Any chance of a ride down ace cafe when she's done mate ???
jonbuoy
Thu Feb 23, 2006 7:21 pm
Glenn, well done geese, hope all goes well and not too many hicup's :D
Just a quick question: I'm chuckin' in a 2.5 lump in my 318, is it just plug and play your does some of the car loom go with the engine loom?
Cheer's
Jon
dips346
Thu Feb 23, 2006 10:04 pm
hoshy wrote:Glenn, amazing, full stop :)
any time i will start a list of people to drive when see is finished ..lol :chuckle:
tylerma
Thu Feb 23, 2006 10:07 pm
I hope I am on there mate winkeye
dips346
Thu Feb 23, 2006 10:14 pm
of course
tylerma
Thu Feb 23, 2006 10:16 pm
dips346 wrote:
tylerma wrote:
dips346 wrote: any time i will start a list of people to drive when see is finished ..lol :chuckle:
of course
you are a star
:thumb:
going bed now
will call you tomorrow afternoon
sorry for the O/T
Demlotcrew
Thu Feb 23, 2006 10:48 pm
jonbuoy wrote:Glenn, well done geese, hope all goes well and not too many hicup's :D
Cheer's
Jon
Plug and pray.
You will need to change the coding plug on the clocks to accept the new engine. (as well as a whole host of other bits)
Andrew
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Thu Feb 23, 2006 11:01 pm
gonna be a long list :)
jonbuoy
Thu Feb 23, 2006 11:07 pm
Cheer's
Jon
Plug and pray.
Andrew
I remembered this the other day but need to right thing's down as i've not got a brilliant memory :?
Would you mind telling me what i need to do at the Ace Cafe meet please Ant?
glenn
Fri Feb 24, 2006 7:53 pm
dummy-fitted the whole lot back onto car this evening.
only took about an hour and a half to fit gearbox to the engine, mount it on the crossmember, lift the car out of the way, position the engine where we wanted it, then brought the car back over the engine/box. then lowered the car to the desired height onto axle stands, then lifted the engine/box up into the engine bay. the gearbox fits surprisingly well into the tunnel.
tomorrow i'll make the gearbox mounting and shorten the gear linkage.
oh!... and take some more pics.
Dan318-is
Fri Feb 24, 2006 7:55 pm
i love the way you just say "make the gear box mounts" and things like that
best off luck to ya
glenn
Sun Feb 26, 2006 5:42 pm
a couple of pics for you
engine mountings
brake master cylinder and hydraulic booster on modified bulkhead
and two pics of how well the box fits in the tunnel
DieselMeister
Sun Feb 26, 2006 5:59 pm
Nice
dips346
Sun Feb 26, 2006 6:26 pm
looking sweet 8)
appletree
Sun Feb 26, 2006 6:41 pm
that is just mad!! :mad:
when are you expectng it to be finished?
dips346
Sun Feb 26, 2006 9:31 pm
appletree wrote:that is just mad!! :mad:
soon i think just waiting on parts now
Grantley
Mon Feb 27, 2006 6:21 pm
Just looked at the thread for the first time :clin: :clin: :clin: , huge respect Glenn that has to be the ultimate conversion. Are you putting in a bigger fuel tank ?
Morat
Tue Feb 28, 2006 3:35 pm
I wish you would set up a production line of these. I know a lot of the fun in owning a conversion is being unique but... imagine a team of E30 V12s beating up Run what you Brung at drag strips all over the country :D
edit: What will the power to weight be when you're done?
glenn
Tue Feb 28, 2006 6:11 pm
no
this M70 is 300bhp.
aauser
Tue Feb 28, 2006 6:58 pm
Fantastic - can't wait to see & hear the finished article - Glenn, I take my hat off to you mate :D
Dan318-is
Tue Feb 28, 2006 7:11 pm
superb conversion; but 300 brake from a v12, how many litres? :?
Whats the torque?
Glenn isnt your V8 400?
buster
Tue Feb 28, 2006 7:15 pm
318-is wrote:superb conversion; but 300 brake from a v12, how many litres? :?
Whats the torque?
yeah but these things are like duracel bunnys,they just go on and on and on and on ................ you get the picture.
Low stress engine.Nice
BTW ,nice one glenn for doing another conversion,many more pics please 8)
thesaint
Wed Mar 01, 2006 1:52 am
impressive, saw pictures of a jag v12 in one somewhere i think
1986 325i - Gone. 1993 318i touring, m52 in the planning stages.
jonmsm
Wed Mar 01, 2006 2:12 am
It has to be said Glenn - you are the man.. could do with someone as productive as you around my workshop/garage/tarmac! I have a 320i track car and a spare M30 3.5 that is to evenutally find its way into the 320... thats got to be an afternoons job for someone of your talent... if you get bored of the v12 (IF thats even possible) then you know you can always come help me with that and my m535i thats going back on the road... :P
do you think its possible and fairly easy to do a similar conversion to an e28 (must be - EVEN bigger bonnet still).. I would LOVE to have a HUGE lazy slacker german V12 in my M535i for the 'ring or even a less lazy and more 'athletic' M5 v8 in there to do some show stopping at the pod.. and to shut up my mates who like to point out its an M5..... 35 and that his 300bhp mr2 turbo is much faster, or my other mates chavette AND his corsa are quicker (BLOODY 160bhp VAUXHALL XE ENGINES ON R1'S!!)...
How much is it costing to do the conversion with the V12 and would my newly re-installed LSD handle it.. because that was a sod to lift into place with nothing but my scrawny arms! LOL
Sorry for the long post, its late im bored and have much to say! LOL
1986 e28 M535i (gone and missed)
1988 e30 320i cab (full resto STILL in progress)
1996 Volvo 850 T-5 estate (280bhp Turbo Nutter), T-5R (my precious)
1966 Fiat 850 saloon & 1970 Sport Coupe
C1 (go-kart)
