hi, i have a e30 320i,
when i press the accelerator pedal just a little bit, nothing happens or sometimes the engine wants to stall.
i have to press the pedal further down to get a response...
i have replaced the spark plugs, but still the same..
any idea please?
e30 320i idle advice and help needed , thanks
Grantley
I know this sounds silly but have you checked to see if your throttle cable is adjusted correctly ?
m3mpower
no, i havent checked the throttle cable, is that the accelerator cable??
Grantley
yes it is
