car stereo heating
michael24m
Post Sat Feb 18, 2006 9:17 pm
in my e30 the cassete unit i had before and the cdplayer that is currentyl installed both seem to be overheating, for example when i pull out the cassete or the cd is warm-hot like after half an hour of playing...the cd seems to be hotter than it were spinning in a 52x pc cdrom unit copying it!
is that normal? i seem to be having the same with both stereo units and the wiring is teoreticaly correct.
Post Sat Feb 18, 2006 11:04 pm
Nothing you can do with the wiring can make it overheat, except perhaps using speakers with too low an impedance.
Depending on heater settings, the unit can live in a fairly warm enviroment and pushes out quite a few watts of sound from quite a small box.
Don't think there's a problem.
WARLOCKM42
Post Sat Feb 18, 2006 11:21 pm
Must not be a problem dude u can have a BBQ made on my Alpine and it works fine.Double check cables just in case...
316eyes
Post Sat Feb 18, 2006 11:27 pm
Mine gets hot too! Has been doing for 2 years and not had a fire yet.
michael24m
Post Sun Feb 19, 2006 11:50 am
thanks guys, i'm at peace now, both my units were quite warm, and indeed there doesn't seem to be any problems except the heat
