Progress has been pretty slow on this - which really suited me with the way my CRX went off piste - but plenty of work has been going on in the background. And more scope creep.
Anyway - the car had a new timing belt done about 7 years ago - at most its covered 1k miles since then, but it made sense to replace it ahead of it doing any sort of serious mileage. On top of this, the steering rack actually crapped itself about a fortnight before the car was send over to the UK - so that needed fixing. Rather than replace like for like, I went for a purple tag as an upgrade. Bought one and never even unwrapped it - just threw it in the boot. Figured it was worth having it refurbed, so sent it to Sam Calver who specialises in this sort of thing. He uses OEM seal kits, and blasts and repaints the rack. Turns out mine was unusually clean - so just needed the seals to be replaced.
After that, the car was transported to the best in the business for these - Dan Harborow - who is clearly well known around these parts!
Dan was tasked to look after the timing belt and water pump as well as the rack upgrade. Car wasn't with him long when....
Turns out the cause wasn't anything too severe - coolant had been drained out years back when there was a small leak spotted once the dash came out, we're guessing the jubilee clip here just wasn't tightened up properly.
That said - there were still multiple coolant leaks...
Dan found some ports blocked off incorrectly, as well as the wrong bolts used for the gearbox which caused the most significant leak.
Looked a good bit better after a clean up -
Rack and new hoses in place -
While he was there - he also rerouted the washer hoses correctly - my mistake
New lollipop bushes and mounts were done - as well as engine mounts -
And undid a bit more bodgery...
And ready to roll out again... back onto a transport truck
Was great to have Dan working on the car - well and truly an expert on these - and plan on spinning back over again at some stage for some more work.
