Hi All,
I took out my seat belts when the car was getting painted. I am trying to put them back, but the belts won’t come out of the houses as if the interns is locking all the time. Any clues how to pull the belts out. All four are different as well which I thought was odd.
Regards
Richard
Why does iPads work better than pc’s for this website.
Installing rear and front seat belts
RTTBMW
E30 325i Mtech 2 1990 (Registered in 1991)
flybynite
You need to get the belts bolted in, in the correct orientation that they were designed for, then SLOWLY pull the belt out. When fully retracted the spool is full and spins the centre too fast and locks. You need to SLOWLY pull out a foot or two and you will be fine. First couple of inches can be a pain.RTTBMW wrote: ↑Sat Jun 27, 2026 5:08 pmHi All,
Always used a PC on here, never had a problem other than when the site had problems. What problems are you having with a PC?
RTTBMW
Pc at work and home don’t like this website. I’m wondering is the DNS settings for the webiste an issue.
I’ll try the belts tomorrow thanks.
flybynite
Strange, I can get on here and log in on a few different PCs and locations. Have you tried the usual things of deleting history and site cookies etc etc
Maybe ping Steve or Mart a pm to see if he can look at your account
Hope you get the belts out ok
RTTBMW
Belts thankfully came out once they were installed. Front belts seem to have too much stains and wear that I have bought another set on ebay. Passenger side must have got glue or over spray from previous owners work. It just went hard in places and would not coil back at all.
Thanks. I'm on another laptop to see if this one has no issues.
