Hello Zoners
Tearing my hair out with this one. Swapped my engine from a m40 to a m42.
All was going well and driving fine but then the car started to idle roughly, it almost splutters a tiny bit. It’s making the car shake a little with idle, but when it’s moving it’s great.
I have replaced:
- ICV (twice)
- intake boot
- vacuum connector thing
- spark plugs
Also ran multiple smoke tests with no results.
Any ideas would be appreciated!
Scott
M42B18 - Lumpy Id
Scottlaw
Has it got a standard ECU chip? 318is engines are very fickle when it comes to this! Also worth checking basics such as good engine-to-body earth strap, and do a compression test to ensure all cylinders have about the same reading.
Scottlaw
Standard yes. Would a chip from you potentially improve it?
Steve
Coolant temp sensor or MAF?
webmaster@e30zone.net
