Hi all,
Swapped my E30 from a B20 to a B25, I've accrued a few spare parts all for sale, I'm happy to accept lower offers if you take a fair chunk of it as I need it all gone. All items are dirty but perfectly functional to the best of my knowledge unless otherwise stated. Location: Warwick, UK.
- Power steering rack £30
- Ebay backbox £20
- M20B20 base manifolds £20
- Distributor plus brand new rotor £40
- Distributor £15
- Facelift water pump £10
- Pre-facelift water pump (brand new, damaged box) £20
- Fuel pressure regulator £30
- Vicsous fan assembly (fan and clutch) - fan is slightly damaged, some muppet has previously cut a whole in one blade. £15
Pictures are available, but apparently they're too big to add for all items, so I'll share on request.
Email alex_clark96@hotmail.co.uk, starting subject line with "E30 Parts" for more details/pictures.
Edit: some parts have sold, some will soon be scrapped, what remains is till listed here.
BMW 320 Spare Parts Sale
32025RustMachina
Last edited by 32025RustMachina on Wed Oct 07, 2020 3:56 pm, edited 1 time in total.
32025RustMachina
Anyone at all? Else I'll likely scrap the cheaper parts and sell the rest cheap on fleabay
Lemon98
Do you know if the Janspeed back box bolt up directly to a factory twin pipe system with a cat?32025RustMachina wrote: ↑Tue Sep 15, 2020 4:23 pmHi all,
- Front Springs (may be for lowering, sorry I don't know) £10
- Janspeed backbox £40
- Ebay backbox £20
- M20B20 base engine (Block, head, rocker cover, manifolds) £100
- Distributor £15
- Various coolant hoses £20
- Injector power rail £10
- 6x M20B20 injectors £30
- HT leads (one is smashed up) £5
- Crank vibration damper £5
- Crank and aux pulleys £5
1990 4-door 320i SE
rix313
Well constructed advert
Please add some photos of parts as per forum rules though please
32025RustMachina
The backbox would, but it is a little damaged and would need welding to the current exhaust system or some pipes and then clamping on. I can weld on some pipe sections if someone wants that.
Thanks Rix, I don't think the forum can take all of my photos due to their resolution, is it fine then that I only upload 4 or 5 photos?
Last edited by 32025RustMachina on Sun Sep 27, 2020 3:52 pm, edited 1 time in total.
Fire up as many as you need to mate !!32025RustMachina wrote: ↑Wed Sep 23, 2020 8:12 pmThe backbox would, but it is a little damaged and would need welding to the current exhaust system or some pipes and then clamping on. I can weld on some pipe sections is someone wants that.
The more the better so all can see what you have and you will sell these better and hopefully faster.
Cheers Mart.
Lemon98
I'm in Coventry and am interested in the B20 engine, what year was the car that it came out from?32025RustMachina wrote: ↑Tue Sep 15, 2020 4:23 pmHi all,
- Ebay backbox £20
1990 4-door 320i SE
M3kuksport
Preface water pump available?
32025RustMachina
Yeah it is, completely unused, but box is water dmaged from when my flat flooded last year.
black-e30
Hi
Is distrributor cap and rotor still available?
